Oil addative to address dry start knock?
Old 12-13-2011, 06:36 PM
vette67's Avatar
Originally Posted by Yankee
Don't both just increase viscosity and in effect, give more cushion between parts?
i don't think so. Some of them are pretty thin, and they are supposed to bond to your internal parts. Like marvel mystery oil. I've used that in several cars and had pretty good results.
Old 12-13-2011, 07:51 PM
dougehr1's Avatar
I think i saw something for race cars once on internet called preluber.hit a switch electric pump sends oil to oil galley through a port in block.maybe check that out.
Old 12-13-2011, 07:57 PM
f2fast4u's Avatar
Just put a blue bottle of STP Oil treatment in there. I've been doing that to all mine for years. No problems on this end.
Old 12-14-2011, 11:26 AM
munch520's Avatar
Had these and turbo timers on my built VWs/Audis worked perfectly when trying to 'prime' or circulate oil after a hot shutdown.
Old 12-15-2011, 02:21 PM
Hiball's Avatar
Next time you change your oil, substitute 1 quart of Slick 50 for one quart of oil. The Slick 50 will leave a thin film on the moving parts of the engine which will eliminate the cold start issues. I've used it on many vehicles.
Old 12-15-2011, 03:53 PM
wheels082's Avatar
Personally, I am not a fan of oil additives. I use Amsoil synthetic oil along with one of their filters and have not noticed any dry start knock. I currently use the 5w20.
Old 12-17-2011, 10:47 AM
Zombie Hunter's Avatar
Originally Posted by efan450
When it really cold, I hold the gas pedal to the floor and crank the engine for a few moments...stop cranking release the pedal and start it normally.
The computer won't let the Jeep start if the gas is held wide open so by cranking and not firing will get some of that oil up top before the engine starts. Every time I do this I don't get a dry start knock...not the best solution but still better then dry starting.
I've never had this "dry start knock" issue, but just tried the above and it WORKS!
Old 12-17-2011, 10:50 AM
x2, but I use the 5w30.
Quick Reply: Oil addative to address dry start knock?
