Oil Change Computer
I'm still a bit confused...I had an oil change about 2500k ago and it tells me to change the oil now...does it need to be reset or something?
Does it have a sensor that tells the computer that the oil has been changed?
08 jkux
08 jkux
No, it has to be manually reset every time you do an oil change. I can't remember the button sequence to press, but I'm pretty sure it's in the online owner's manual (as I recall, it was a combination of key turning and accelerator pedal, but I don't remember the exact steps).
Turn the key to accessory (lights on the dash lit, but engine not started), then push the gas pedal in and let it out slowly 3 times (within 10 seconds), and then turn it all the way off. Then start the Jeep and go about your day.
Happy Jeeping!
Thanx! Just when u turn it all the way off, do u remove the key? Last, will there be a beep or a flash or something to indicate that it's been reset?
