Oil Change Problem
Oil Change Problem
Took 2013 sport to friends shop for oil change. He could not remove the oil pan plug,asked me who did last oil change,which was the dealer. Told me to take it back to them,maybe they cross theaded it. dealer had to use air hammer to loosen it.No charge for oil change or new plug. Asked head mechanic if this a common thing. He told me the plugs are made of crap metal,happens more than you think. Anyone else have this happen?
This is just weird. I freakishly change oil every 3k miles and have done so for the last 25 years or so. Never, have I seen a bolt cross threaded in the oil pan. Most likely put it in with a pneumatic wrench. General rule with any bolt, insert by hand, then tighten to spec. Following this method avoids cross threaded issues. Mechanics......... SMH...........
I've changed my own for 30 years. Finger tight and hand tighten with a 17 mm I think. No reason to use a power tool there and over tighten.
Sent from my iPad using JK-Forum
As a boy I was taught that to find the starting point of any machine screw, slowly turn the screw counter-clockwise (left/loose) until it "clicks" (more of a feeling than sound). Then begin to turn clockwise to tighten.
I honestly can't recall the last time I cross threaded a screw or bolt.
As a boy I was taught that to find the starting point of any machine screw, slowly turn the screw counter-clockwise (left/loose) until it "clicks" (more of a feeling than sound). Then begin to turn clockwise to tighten. I honestly can't recall the last time I cross threaded a screw or bolt.
Another victim of the "idiot factor". Far more idiots these days turning wrenches than actual mechanics. The precise reason no one touches any of my vehicles with a 10ft pole unless it's a costly warranty issue and even if it is, I'd usually do it myself still.
This is a simple bolt to thread but generally the art of understanding functionality and troubleshooting to component level is pretty much gone. Now it's throw parts at it until it's fixed and instead of taking your time and pride in your workmanship, it's get it out the door and collect the $. Oops, did I say too much ?
I'd also have to question the condition of the pan threads if the bolt was, in fact, cross threaded. Next change, take it back to the dealer and ask to see for yourself. They should give you a new pan if so.... then after that, do it yourself.
Do everything you can yourself. Invest in the tools, take the time to learn and you'll be far better off for it.
