Oil sucking 3.8
Early 07 (built Dec. 06) Rubi Unlimited 81k miles
In July ran about 3500 miles from Florida to Auburn Hills, Mi. and return-- consistently used 1/2 quart per 1000 miles--run Royal Purple 10-30 and have cleanable oil filter with oil temp and oil pressure gauge @ 65 MPH (which I usually run run on I-states) 55 pounds pressure and 215 degrees F, water temp 202-206 degrees (Scangauge)--have used RP since 5000 miles, very happy--a little less oil use in town--with add ons, full fuel, 2 people Jeep weighs 5200 lbs.(by truck scale)--CRWood
Also, 1 quart every 2k is an oil user to me. I've never had an engine use more than a cup every 3k miles, and most engines I've ever had used no oil at all. None of my other vehicles uses so much as a drop. My Chevy van has a 6.0 liter that gets an oil change every 9k miles. It doesn't use a drop of oil over the entire interval. (I run Pennzoil Platinum, Mobil 1, or Quaker State Synthetic, depending on which is on sale. That engine has no usage with any of them.)
IMO Any modern engine using oil below 100k miles.....had an assembly/material quality problem from the get go, or was damaged through abuse or plain bad luck. Rings,valve guides, cylinders out of round....something. But is not ok, and not the norm.
I respectfully disagree. Thats what the automakers say as a cop out. Only engines I ever had burn oil were the old late 60's V-8's with over 100k miles with me hot rodding the hell out of them.
I asked what the spark plugs look like a few posts ago. Their condition/color may tell a lot about what is happening to the oil. We have not heard what the tailpipe looks like either.
But, I know it's impossible for all engines to be made so they don't consume oil. It just can't be done in a mass production environment. That's why there is a threshold, prior to which they won't do anything.
Yes sir, I understand. It just seems way to common, even given the nature of a forum environment, in these JK 3.8's. In this case I think the long standing "1 qt every 1000 is okay" is a disservice to these consumers and is damaging to the Jeep brand.
I'd like to see what percent of all JK 3.8s burn oil.
I just can't get upset about it until I see what's actually going on.
(I know. Mine's not burning oil. So, it's easy for me to say that.)
There's a good number of threads on this topic, and I just wonder if any Jeep Engineers are actually READING this. They can hide behind a avatar and none of us would know...great way to learn how the customer likes / dislikes your product. ( We do it in our industry...free honest feed back)
So, HELLO JEEP ENGINEERS I'm sure you're out there!!! How's about stepping up and helping out here!
In addition to this issue, feel free to use this forum to take care of the steering klunk, and e-brakes that need constant adjustment.
OWN UP TO YOUR DESIGN GUYS!!
