View Poll Results: What's your odometer reading? Problems??
Voters: 1042. You may not vote on this poll
This is a poll for the JK 3.8L V6 and it's engine longevity. Engine problems so far?
#531
07 sport with teraflex lift and 35's.
Light bars, smitybilt bumpers extra..
Even with the Dana 35 in the back havnt had any problems and just hit 110,000 km
Only complaint is the underpowered engine. But got a superchip and that helped a bit. Debating a cold air intake.
Love this jeep!
Love this jeep!
#532
07 sport with teraflex lift and 35's. Light bars, smitybilt bumpers extra.. Even with the Dana 35 in the back havnt had any problems and just hit 110,000 km Only complaint is the underpowered engine. But got a superchip and that helped a bit. Debating a cold air intake. Love this jeep!
#533
Ya was a couple weeks late 5 years ago, and they said I was SOL. that kind of sucks since I was moving, but on the plus said 10 years old and no real issues.
#534
I did some more research and I'm stuck now between doing the CAI + throttle body spacer or a good exhaust system.
#535
Both the CAI and throttle body spacer are a waste of money..
Throttle body spacers were only effective when fuel was injected at the throttle body BEFORE the spacer.
CAI under hood are not cold air they pull in hot engine bay air. Only a snorkel is a CAI.
#536
More and cooler available air with better flow characteristics allow the computer to increase the injection on time, allows for better cylinder filling and allows the fuel to better mix in the airstream. More fuel and air into the cylinder equals more power out at bang time.
#537
Cold Air Intakes are designed to allow a higher air flow and smoother air flow into the engine (part of what the throttle body spacer helps with - the quality of air flow). All the ones I have seen use the stock air box location which draws cooler outside air in for combustion. More and cooler available air with better flow characteristics allow the computer to increase the injection on time, allows for better cylinder filling and allows the fuel to better mix in the airstream. More fuel and air into the cylinder equals more power out at bang time.
If you do a search you will find data from fellas that have recorded actual air intake temperatures and found that the temps are much higher from the CAI.
The computer controls all air in and fuel. Your computer would require a custom tune to take advantage of any extra air the CAI could add.
As for the TB spacer, again that is old tech
designed to help atomize the fuel which can only be done if the fuel is injected before the spacers though a TB or carburetor. It does not benefit multiport injection in the least. If you want to see any kind of intake difference on the 3.8 you can add the 2008 Viper 74mm TB to replace the 58mm stock one.
#538
A new intake with a filter isn't a CAI it's a new intake. The CAI will seal against the hood or have a whole air box that draws from either a snorkel or the factory outside air supply.
The computer measures throttle demand to determine how much air it needs, measures that air to determine how much fuel it needs and feeds the fuel into the air (yes, downstream of the throttle body), and applies spark. If it measures more air it will, up to the limits of the injectors, add more fuel as power is demanded so allowing more volume of denser air allows more fuel to be added producing more power.
I can't answer to all the fellas for what they have installed, nor for their testing methods or measurement accuracy. I can say that it is a simple equation, more air plus more fuel equals more force against the rod causing more rotational force on the crankshaft. If it isn't a well designed system and it isn't a CAI then it is what it is. Don't buy cheap.
#539
136K miles. K&N Intake, Ripp long tube headers, better plug wires, Mobile 1 5W20 since the first oil change. Manual 2008 JKUR on Terraflex Pre-runner 4" and 35's.
Uses more than a liter between 6000 mile changes, starting to feel a little low on power. I need to do a compression check soon. Searching for other options (Hemi, new 3.8 long block, used 3.8, building this 3.8, adding a Ripp S/C, or the new Cummins)
The only issues I have had with this engine besides lack of power is a water pump at 6K miles and cracked exhaust manifolds at 80K. Driven HARD. I even towed with it for probably 20K miles, over mountains in the summer.
