Sponsored by:
Sponsored by: DashLynx
Question about double clutching
Old 02-22-2017, 07:33 AM
jedg's Avatar
Originally Posted by SimpleSimon
I think what may of snapped was your brain...what made you think double-clutching was the thing to do in a jeep?
Welcome to JK-Forum.
Old 02-22-2017, 07:55 AM
SimpleSimon's Avatar
Default ....
Well thank you. appreciate that!
Old 02-22-2017, 08:00 AM
blackie27's Avatar
Thanks guys, sounds like I need to stop it! Appreciate it.
Also, I definitely won't tell the dealer about my experiment
Old 02-22-2017, 08:09 AM
Blackie, I'm not ragging on you, just curious why? why did you feel the urge to 'experiment'- maybe you just never owned a manual before?
regards
old grouchy old man
Old 02-22-2017, 08:13 AM
blackie27's Avatar
Blackie, I'm not ragging on you, just curious why? why did you feel the urge to 'experiment'- maybe you just never owned a manual before? regards old grouchy old man
I wasn't feeling ragged on at all. This is the first manual I've owned, and friends said that I should learn how to double clutch. But it sounds like they don't know what they're talking about. I guess I felt the need to experiment as in Colorado there are some big steeps to climb on the highway and I was looking to get a smoother downshift as it would jerk a little, not much on the downshift. Im more curious if I did real damage, but it seems to be driving fine. It's great having the forum because I don't have any close friends that have owned a jeep long enough to answer some of these questions I have
Old 02-22-2017, 08:32 AM
I gotcha- we don't have any hills here in Delaware, it's flat as a pancake. So don't have that problem. kind of jealous, because I like hills. And you need different friends 'Friends' will get you into all kinds of trouble! Also, I think only time will tell if you've ruined your transmission. cheers
Old 02-22-2017, 09:21 AM
spmitchell86's Avatar
I have the 6 speed and totally understand that jerk sensation... I believe the technique you need is called rev-matching. Once you depress the clutch to go from 6 ----> 5 give it a little gas to bring the rpm to where they'll be in 5th.
Old 02-22-2017, 09:57 AM
blackie27's Avatar
That makes sense considering that's what you're ultimately trying to accomplish with double clutching. Thanks man
Old 02-22-2017, 10:12 AM
No problem! Also since it's your first manual you can use that difference in RPM to actually slow down using less brakes. That technique is called engine braking.
Old 02-22-2017, 10:48 AM
blackie27's Avatar
That's not too hard on the engine down shifting on a decline?
Quick Reply: Question about double clutching
