Sponsored by:
Sponsored by: DashLynx
Parking lamps
Old 09-13-2012, 05:43 PM
Hrdtyme's Avatar
Default Parking lamps
I'm having a problem with my parking lamps. When I turn them on the left side is out but the blinkers and brake lights work. It's only the left front and back parking. I checked the bulbs and they are good. Any ideas?
Old 09-14-2012, 03:13 PM
Four Low's Avatar
I had the exact same problem - drivers side parking lights out front and rear . It's a 15 amp mini- fuse in the underhood box next to the battery. It's called " M17" if you can read the tiny print. I located it by color, blue is 15 amp. Blue, red, blue, natural . The blues are right and left parking lamps. Why did the fuse blow? The dealer says it could be the PCM , has to happen again. I got a ticket for Chryslers fail, located and replaced fuse when I got home
Old 09-18-2012, 09:00 PM
Hrdtyme's Avatar
Default lamps
Thank you for the info
Quick Reply: Parking lamps
