Quick question on Brakes
Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2011
    Location
    Kansas
    Posts
    123
    Default Quick question on Brakes
    I just finished putting rear brakes on my 2008 JK with 32,000 miles. The outside brake pads were only 2/3rds worn out, but the inside brake pads were shot.
    Here is my problem/mess up. I broke the piston/caliber clip off the one on the driver side. I went ahead and finished the rears. I had to turn the Jeep around to get the passenger rear as my garage is to small to do it in otherwise and everything felt great. I am going out for a test drive, but was wondering if this is something that will cause more damage if I do not replace the new brake pads with new ones with the clip (the passenger side was no issue and has the caliber clip).
    I also reused the original retaining clips as the brake pads did not come with any.
    I also forgot to use the lube they comes with the brake pads for squeaks. I got these at AutoZone and they were the more expensive ones and not the cheapest ones.
    Any thoughts would be welcomed and appreciated. If I ask a local garage they will tell me to replace the brake pads just for the buisness.
    2008 Black Rubicon JK Auto with full Rubicon Package
    Black Rock Viper 17x8
    Goodyear Silent Armor 255/75/17
    ACE Rails
    Mopar Gas Door
    Several small interior mods/additions
    I could have taken it any direction in mods, but this works for me.
  2. #2
    JK Super Freak JKingAround's Avatar
    Join Date
    May 2012
    Location
    Grant Florida
    Posts
    1,386
    Auto zone pads are guaranteed take them back and get new ones.
  3. #3
    JK Super Freak kaptkrappy's Avatar
    Join Date
    Aug 2011
    Location
    Punta Gorda, FL.
    Posts
    1,215
    Quote Originally Posted by wesplains View Post
    I just finished putting rear brakes on my 2008 JK with 32,000 miles. The outside brake pads were only 2/3rds worn out, but the inside brake pads were shot.Here is my problem/mess up. I broke the piston/caliber clip off the one on the driver side. I went ahead and finished the rears. I had to turn the Jeep around to get the passenger rear as my garage is to small to do it in otherwise and everything felt great. I am going out for a test drive, but was wondering if this is something that will cause more damage if I do not replace the new brake pads with new ones with the clip (the passenger side was no issue and has the caliber clip).
    First, it sounds like the caliper pins might be froze up (see pic). The caliper squeezes from the back and front at the same time, if the pins get rusty or frozen it will only push from the back and may create/cause the kind of wear you descibed.
    There is a write up on rear brake replacement on PROJECT-JK.
    As for the rest, I might just start over with new pads and clips. I would never trust something rigged up or broken, especially on the brake system.
    Click image for larger version.
Name:	Rear Caliper w arrows.JPG
  4. #4
    Join Date
    Sep 2011
    Location
    Kansas
    Posts
    123
    1. JKingAround,that would mean pulling the new ones off. When I drove around town they seemed fine.
    2. kaptkrappy, the pin/clip that broke was from the new brake pads. I used the write up to go by. It and other write ups have really been a big help in doing my own upkeep on the jeep.
    Thanks guys for the replys. I will stop by AutoZone tomorrow and see if they will front me the replacement brakepads so I can only have to take it apart once. Then take the old/new ones back.
    Like I said I drove around town and everything seemed fine. I do not know enough about brakes to know if that pin/clip is critical or not. Hoepfully others will chime in.
    ACE Rails
    Mopar Gas Door
  5. #5
    Join Date
    Sep 2011
    Location
    Kansas
    Posts
    123
    Talked to a friend who is a certified mechanic. He said i was fine. Just wanted to be sure. Thanks again for the responses.
    ACE Rails
    Mopar Gas Door
  6. #6
    JK Freak Mike Davis's Avatar
    Join Date
    Jan 2009
    Location
    Scituate, MA
    Posts
    843
    The retaining clips/sliders can be purchased along with slider pin rubber boots. I got 2 sets from Amazon. A set for me and one for a friend. BTW both his and my left rear pads had a spring/slider clip missing. We both added the missing one. Kit # Raybestos H5774A Disc Brake Hardware Kit
  7. #7
    Join Date
    May 2012
    Location
    Grant Florida
    Posts
    1,386
    You'll have to buy the pads and then take them back and get your money
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
