Radiator Drain
Radiator Drain
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Radiator Drain
  1. #1
    Join Date
    Feb 2011
    Location
    Edmond, OK
    Posts
    8
    Default Radiator Drain
    How the hell do you get fluid to drain from the radiator drain. I have turned the knob 1/4 turn clockwise and no fluid is draining out... What the f*** am I doing wrong.
  2. #2
    JK Enthusiast txjeeplover's Avatar
    Join Date
    Feb 2007
    Location
    Austin, Texas
    Posts
    333
    Quote Originally Posted by bhandaman View Post
    With a cool engine, I've always found it easier to just loosen the lower radiator hose and slip it off. I've had issues in the past with drain ****s becoming clogged while draining, cross-threaded while re-inserting, or o-rings walking off. Taking the lower hose off just does the job faster.
    If you're determined to get the drain **** open, hopefully someone else will have some sage wisdom on opening it properly without damaging the radiator or the drain ****.
    2008 2dr Rubicon aka "Beau"
    4" Zone lift as a base with Teraflex and other components
    35x13.50R15 Toyo Open Country MT
    15x10 Ion 138
    A bunch of other stuff
  3. #3
    JK Junkie Jiblet's Avatar
    Join Date
    Dec 2008
    Location
    Boston, MA
    Posts
    2,183
    did you open the cap so the fluid can flow without creating vacuum?
    You may have some grit built up blocking the drain. Maybe poke a zip tie in.
    BTW, anyone know the direction of flow of the coolant when engine is running? is it still in at the top of the radiator and out at the bottom?
    2008 Jeep-Green Rubicon 2-door Automatic
    In theory, there is no difference between theory and practice. But, in practice, there is.
  4. #4
    JK Newbie rumnreggae's Avatar
    Join Date
    Feb 2010
    Location
    Slidell, Louisiana
    Posts
    9
    I just replaced my water pump at 85K and the removal of the lower hose worked best for me.
  5. #5
    JK Enthusiast StrokeHerAce's Avatar
    Join Date
    Oct 2010
    Location
    Lugoff, SC
    Posts
    358
    The only thing those drains have ever done for me is leak once touched. I take off the lower hose after I siphon out what I can from the top.
    You can get a Hummer in a Jeep, but you can't get a Jeep in a Hummer
  6. #6
    Join Date
    Feb 2011
    Location
    Edmond, OK
    Posts
    8
    Default Thanks
    Thanks for the reply's... I honestly believe it would be easier to shoot a hole in the radiator and patch that then to actually drain it using the drain plug. First of all no human hand can reach the plug knob so I had to use a pair of needle nose plyers and contort my hand to try to turn it. This took about 15 minutes. Then, once I got it turned... nothing happenend, so I tried running a piece of wire up there to no avail. The only way to really reach the plug is to remove the bumper. So, let me congradulate the engineers and designers at Daimer Chrysler for their excellent design. Now, stick it up your arse.
    I pulled the hose and drained it that way. What crap!
  7. #7
    Join Date
    Dec 2008
    Location
    Boston, MA
    Posts
    2,183
    bump......
    Quote Originally Posted by Jiblet View Post
  8. #8
    JK Enthusiast 07Ruby's Avatar
    Join Date
    Dec 2007
    Location
    Greenville, SC
    Posts
    151
    bump......
    Bump again.
    Refilling coolant after lower manifold gasket change.
    2.5" Teraflex coil lift
    35" BFG KM2
    Pro Comp Xtreme 7189 Cast Blast Wheels
    OR Fab Tire/Can Carrier
    JKS adjustable track bar
    Rugged Ridge XHD stubby w/ hoop
    Smittybilt XRC-10 Winch
    Windshield mounted KC Highlights
    I would rather be
  9. #9
    Join Date
    Feb 2013
    Location
    Reno, NV
    Posts
    1
    Same issue here, what's the point of the damn thing if it won't drain? Turning, pulling out, wire up the hole, NOTHING WORKS!!! Guess I have to try the hose. Such a simple process made impossible... Wish I had a garage....and maybe even a paved driveway...
  10. #10
    JK Super Freak shabbernigdo's Avatar
    Join Date
    Nov 2012
    Location
    missouri
    Posts
    1,025
    you have to twist and pull it out at the same time. i got mine to drain but it just pissed all over. the guy who decided on that drain design should be shot in the d.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
