Radio keeps resetting
hey everyone, my stock uconnect radio in my 2011 sahara resets about every other day. the clock resets and my background resets. my radio stations are still programmed but the equalizer and everything else resets... any idea??? thanks
Not sure if it helps, but I recall reading one of those service bulletins which had to do with a faulty radio.
I think they reprogrammed it or something. Try "google-ing" it, as today's kids say.
Did you ever figure anything out? My non-nav 430 will randomly reset itself exactly as you described for no reason.
My '13 with 430 Nav does this alhough not nearly as often. Has happened about 3-4 times in the year I've owned it. Would like to get it fixed though, just haven't put in the time.
My aftermarket pioneer did this for a while. It was about every other week it would reset itself. It seems to have magically stopped though because it hasnt happened in a while.
Check the obvious - battery terminals. Are either of them lose enough to turn with your hand? Moisture and a loose terminal did this to mine for a while.
