Sponsored by:
Sponsored by: DashLynx
rattling on start up
Old 09-01-2015, 06:59 AM
Stegs's Avatar
Default rattling on start up
Just wondering if anybody else has this
I have a 2012 jk sport, 3.6
On start up after sitting all night i start the jeep up. Normally it idles around 1000 rpms and slowly works its way down to factory specs
as the rpms drop slowly, it sounds like i have a bicycle bell under the hood....like a heat shield or something vibrated loose
once the jeep is warm it goes away at idle, but then as i give it gas and get into that rpm range its there again.
Wondering if anybody else has a similiar issue?
The jeep is going in for service in a week (grease, oil, tire rotation etc..) i mentioned this to the service guys to look at it....but id love to give them a direction to go if i can
Also i have what seems to be dry starts....first 3 seconds of start up its alot of valve train noise. Is this normal?
Jeep has been dealer maintained since day 1, only has 37k miles on it
Old 09-01-2015, 04:03 PM
kfast24's Avatar
Check the heat shield under the transmission for broken welds on the exhaust. Dry starts are not good probably a bad oil filter if I'd have to guess.
Old 04-02-2018, 06:18 PM
Papa Bear's Avatar
Default Any updates and there’s my issue sound like what you experienced?
Old 04-06-2018, 11:46 PM
jjl509@yahoo.com's Avatar
+1 that is your heat shield on the exhaust
Old 04-07-2018, 06:04 AM
EHarris's Avatar
Heat shield or maybe even exhaust manifold. I noticed mine went bad when I would hear it on cold starts and then go away once the JK reached optimal temp. It's doubtful since you have the low miles but worth a look.
Quick Reply: rattling on start up
