Sponsored by:
Sponsored by: DashLynx
Seal a Roof
Old 03-31-2014, 10:13 AM
saharaharry's Avatar
Default Seal a Roof
Has anyone with a Hardtop, and unfixable water leaks ever sealed the top?
Just a DUMB question out of frustration with water leaks. My wife's 13 leaks
and my 14 X, just 3 weeks old leaks. I work in the auto business, and on my day off
hate spending time in other dealership!
Old 03-31-2014, 04:14 PM
LJ_olllllllo's Avatar
Yupp mine leaks right onto my radio every time it rains and i hit the brakes reasonably hard. Its a 2013 rubi with my old 2012 Sahara hardtop on it
Old 03-31-2014, 04:26 PM
marcusjames2's Avatar
I have an '07 and did have those problems but have since sealed it pretty tight. Go to Lowes and buy some camper top foam. Apply a layer or two in the seam where the t-top meets.
Old 03-31-2014, 04:31 PM
Also, this is a thread I had written a while back. It is more having to do with over the doors, but may help. I had pictures of some of the weather strippings I used.
https://www.jk-forum.com/forums/jk-w...8/#post3514086
Old 03-31-2014, 04:41 PM
Can you still remove the freedom tops. Or do you have to reseal it every time
Old 03-31-2014, 04:51 PM
No, you don't have to reseal every time. They stick pretty well once they've been on there under pressure for a while.
Old 03-31-2014, 06:17 PM
double J's Avatar
Have you tried applying sil glyde to your rubber seals? I've used it on mine and it seems to help.
Old 03-31-2014, 07:10 PM
Not sure if you can tell, but this is how I applied the foam. I have had the hard top off for about a month and the foam stays in place on the top.
ID:	542333   Click image for larger version
Old 03-31-2014, 07:37 PM
AirJordan613's Avatar
Electrical tape on the exterior. Works like a charm
Old 04-01-2014, 05:18 AM
Default Roof Leaks
Since my latest Jeep is a 14 Rubi X, I had thought by now the leak problem would be solved.
This situation has been going on since 2007. You don't have to be a GENIUS to do the math,
but that's like 8 model years they are producing this vehicle with known defects. Yes, DEFECTS.
No matter what your model, you paid GOOD money for a vehicle that they are knowingly building with issues.
I have not even made my first payment yet, and the leaks prevail. No, I am not just venting, but stating
a fact. Was wondering if you fellow Wrangler owners with this problem would be interested in starting a
CLASS ACTION suit to get to a solution or a settlement?
Put in your 4 cents on this!
Quick Reply: Seal a Roof
