Sponsored by:
Sponsored by: DashLynx
Shaking at 65+. Don't think it's my steering.
Old 04-19-2015, 08:45 PM
WyattO1759's Avatar
Exclamation Shaking at 65+. Don't think it's my steering.
Hey there, y'all.
I'm having issues with my Jeep shaking when I hit about 65+. It does not feel like the shake is in the steering, but it's still concerning me. It's a fairly constant vibration and I have no idea what it could be, as everything is stock except for the leveling kit that I have installed. Wondering if anyone else has had issues like this, or if there is something in particular I should look at. Any help or suggestions are welcome. I'll post pictures of stuff if needed. Thanks!
Old 04-19-2015, 09:05 PM
nthinuf's Avatar
Go up to JK Write-Ups. Stuck right to the top is a great shimmy/dw diagnosis thread.
Rather than a bunch of speculation and guessing, you might be better off just going through the writeup and videos and checking a few things yourself. Then come back with the additional questions you are bound to have.
Old 04-20-2015, 03:28 AM
catahoula's Avatar
Tires might be out of balance. Some weights might have fallen off. Happens.
Old 04-20-2015, 05:48 AM
DJ1
Former Member
DJ1's Avatar
This +1. Swap tires front to rear so you can better pin down which set is giving you the shakes. If it's an older tire, could also be "out of round" which means the tire needs to be replaced.
*edit* After checking the balancing of all tires and after the swap from front to rear you are still getting shaking in the front end, then you're going to have to do a more thorough diagnosis on all the front components like trackbar, ball joints, etc.
Old 04-20-2015, 05:52 AM
DJ1
Former Member
DJ1's Avatar
...but yes, still go to the JK Write-Ups section. Best to learn the other causes of shimmy & the extreme death wobble.
Old 04-20-2015, 06:04 AM
Jeek.OlllllllO's Avatar
X2 on the balancing, rotate your tires it should help if not check for wear in the suspension components
Old 04-20-2015, 06:08 AM
Mark Doiron's Avatar
Originally Posted by WyattO1759
Hey there, y'all.
As suggested, follow the death wobble/shimmy troubleshooting checklist written by Planman. Also, answers to questions like this depend on how old/many miles your Jeep has. Fill out your profile to help folks better answer your questions, if you haven't already. And since profile isn't accessible through the phone app, suggest you include that in your question as well.
Old 04-20-2015, 04:30 PM
cfr
cfr's Avatar
Driveline vibration?
Old 04-20-2015, 06:40 PM
PANGMAN's Avatar
Hey there, y'all.
I would balance tires and did you get an alignment after the leveling kit.
Old 04-20-2015, 10:55 PM
WyattO1759's Avatar
I didn't get an alignment after I installed it. That might be a problem.
Quick Reply: Shaking at 65+. Don't think it's my steering.
