should these two pieces of pipe be seperated?
Old 06-29-2015, 12:14 PM
RenegadeUL13's Avatar
I guess seperated isn't the best word because they're still clamped together. but I got my jeep back recently from dealership after they put a new torque converter in it and I have had a rattle ever since. I found it yesterday it was this clamp pictured Click image for larger version
ID:	616383 I'm guessing (I don't really know) it's the header pipes into the Cat? Anyway it's seperated about an inch now and there's a nub on one part of the pipe that appears it should fit in a notch on the other part except it's seperated by an inch... anyway the clamp has been tightened down after soaking it in PB blaster... so the rattle is gone...
Old 06-29-2015, 03:54 PM
jadmt's Avatar
yea it should be pushed together. You will need to push it from the back as the Y-pipe should not move towards the back. The exhaust is rubber mounted from the Ypipe back so should move towards the front.
Old 06-29-2015, 04:52 PM
Thank you. Can it wait until my next service in 4500 miles? Any negative side effects of leaving it as is? EDIT: I'm a dummy... I tried to move the Y pipe... I'll get a wratching #15 wrench and try again... I had one, that foo must have grown legs
Old 06-30-2015, 01:37 AM
14Sport's Avatar
As long as it is not leaking and you've tightened the loose clamp you should be fine.
Old 06-30-2015, 02:43 AM
Thanks, I'm going to try again to reposition it. What pieces am I dealing with here?
Old 06-30-2015, 04:39 AM
14Sport's Avatar
Here's a diagram...
2012 JEEP WRANGLER Exhaust System
It's poorly labelled but looks like the Y pipe and extension.
Old 06-30-2015, 05:51 AM
Mark Doiron's Avatar
The danger is that carbon monoxide can be escaping if that isn't fully and completely sealed. That, clear, oderless gas can work its way into the passenger compartment, resulting in sleepiness and headaches (at first), and eventually death. If you're not absolutely certain that you have any possible leaking contained, you might try one of these as a temporary fix until you can get it properly repaired ...
http://www.amazon.com/Permatex-80331.../dp/B000BXKZ6K
Old 06-30-2015, 06:05 AM
MavisJk's Avatar
I would take it back. If they made the exhaust rattle, what else did they do wrong or forget? Have them go over their work again.
Old 06-30-2015, 07:09 AM
This place is notorious for leaving stuff loose. BUT my check engine light came on and I was 27 1/2 seconds away so I thought it's been long enough maybe they cleaned up their act.
Thanks for the advice guys.
Old 06-30-2015, 01:11 PM
Fixed her. Bolt is incredibly rusted so it was a PITA!
Quick Reply: should these two pieces of pipe be seperated?
