Soft Top Back Window Zippers stuck
Yes, i believe it is. they may just say youre not lining it up correctly but it hard to do that when it just doesnt like to be alined correctly in the first place haha. My rear window does the same thing to me everytime. id say just give it a good tug to get it off. its kinda violent but it works for me. havent seen any wear and tear yet from it either. like others have said, some kind of lube would help too
Thanks for the replies guys. It's good to know you're not alone.
Anyway, i took it to the dealer since it's only 5 minutes away and we basically muscled it off.
So for the next time i made sure it was lined up real good when i put it back up (there's a bunch of showers coming in) and now i can see that the teeth are lined up good this time.
There's a kinda of latch to line up the starting pieces for the zippers that i guess is designed to try and stop the teeth getting out of line.
Thanks again for the replies. Love this site. Might not post too often but make a habit to read it often.
DMTerra8814 (10-03-2022)
btw.... bought mine used and looked the previous owner had issues cuz the zipper tails are frayed and a little discolored...... 2007 jk
Soft Top Zipper
My soft top rear window zipper was so horrible, I GAVE my rear window to another JK that had his rear window cut from vandalism. I told him if he can make it work it's his.
08 2-DR Auto 35's, 3" BDS
JK back window zipper.'.'.'.
Anyhow, I took it back home to wrestle it off, ended up using a big C-clamp and screwed it down right where the tooth was poking out the back of the zipper. Pressed it right back in and worked all summer. Now winter time and i saw a spot in the other corner that came "un-zipped" somehow about an inch long... FML. Wishing I had a hardtop...!
3rd Jeep with a soft top. One of the reasons I never remove my rear window. Yeah it gets scratched, but eventually no matter what you do it gets scratched. Lemon Pledge works great on the windows. Save your money on expensive cleaners.
I always spray my zippers with silicone spray. Another thing to try is Super Lube (liquid). If this stuff can't unstick it nothing can.
Good Luck!
Good Luck!
3rd Jeep with a soft top. One of the reasons I never remove my rear window. Yeah it gets scratched, but eventually no matter what you do it gets scratched. Lemon Pledge works great on the windows. Save your money on expensive cleaners. I always spray my zippers with silicone spray. Another thing to try is Super Lube (liquid). If this stuff can't unstick it nothing can. Good Luck!
