Soft top passenger side window help
What about the vertical corner piece of the top itself? I know sometimes it can be positioned improperly around the corner of the tub and sit too close to one side, causing the windows to not be as tight as they should. Try repositioning this piece around the corner, and see if that helps.
This probably isn't the problem, but it may help.
I'm not seeing the plastic strip in this picture that tucks into the channel on the tub. It should run all the way to the corner. Is it missing or stops too early?
