something fell into shifter console area
Old 05-02-2010, 03:09 PM
justinp.'s Avatar
Default something fell into shifter console area
Somehow a dime randomly slipped down between the tiny gab between the shifter area(6 speed) and the side plastic pieces that enclose the shifter assembly. anyone know where this would end up and how i could remove it?
Old 05-02-2010, 03:14 PM
fadeout's Avatar
taking the console out isn't a huge ordeal... it's not the easiest thing in the world but it's not all that bad either. Just undo the shifter ring it pulls up and see if you can't get to it that way. If not then undo the torx screws on either side of the console and pull on on the E brake( all the way up). The plastic area surrounding it that goes up to the armrest area pulls up with clips starting at the edge of the armrest area. If you still can't get to it the sides unscrew and pull apart leaving you with the area all exposed. hopefully you'll be able to get to it by just pulling up the shifter ring. Good luck.
Old 05-03-2010, 04:28 PM
justinp.'s Avatar
thanks. im assuming that theres flooring underneath the center console area and that it doesnt just drop out to where the transmission is
Old 05-03-2010, 04:49 PM
TINMAN080's Avatar
shouldn't hurt a thing- every vehicle I disassemble for repair has loose change, partially eaten hamburgers inside the console housing....
Quick Reply: something fell into shifter console area
