spare key
spare key
Is there a way to get a simple empty key fob? I still have my original two keys, It's just that both fobs are broken. On one the key broke out of the fob and the other the plastic loop, that holds it on to a chain broke. I just want to take the chips out of the old ones and place them into the new fobs. Or am I stuck paying out my ass for a new key?
Make at least 2 or 3. Buy them on eBay or Amazon. Get them cut at a locksmith or reliably key cutting station. Follow directions for programming new keys in your owners manual. You MUST have 2 original keys for this to work. Save your old damaged keys "just in case"
Keep in mind you can only have a max of 8 keys programmed at once (IIRC). Check the owner's manual to double check that.
I bought mine for $7 from ebay and got it cut for free at Home Depot. Then you just need to program them yourself.
This is different from having a "clone" made from one key. A key and it's clone can't be used to program further copies.
This is because each copy gets a unique number in the series 0-9. And you need two different members of the series to make a further member. But a true-clone of, for example, key-4 is a key-4. And you can't use two key-4s to make a key-5.
But clone-keys work fine in every other way.
Bottom line, you can program up to ten program-copies: 0-9
But you can have infinite program-clones made of any of your program-copies. (Made by an equipped locksmith)
Thanks for the input. I ordered two new shells. So now I might go and program a third just in case. One question about the clone keys. Well they set off the alarm when you open the door? Thanks again all.
