Starting problem ?
Starting problem ?
Hi Everyone ~ Has anyone had this particular problem ? My 2008 JK just makes one click when I try to start it...it's done this almost since I bought it (new), but very infrequently at first. I was able to put the key back into 'off' position, then try again and it would start. Initially I thought it was the battery, so replaced the battery. I now have about 75,000 miles on it and it has gotten worse...more frequent and won't start by turning key to off position and trying again. I knew it wasn't the battery (electrical problem...yet another battery's only a few months old), so I went to the next logical thing...fuel. I pumped the gas a few times and it started right up. I now have to do this every time it happens, which is quite often now. Anyone have any idea what this could be ? Thanks in advance ~Dan
Thanks everyone ! Finally took in to shop (I've a lifetime warranty); they're thinking its the redundant ground issue...if it doesn't work, I'll tell them about the transmission fix... ~D Oh, it's automatic, Wrangler428
Well I have placed a second ground to the alternator, and am hopefull that this fixes the "click, no start" problem. Only time will tell. I do know that a good ground is every bit as important as a good positive connection, and this seems to ground directly to the engine block, so it may do the trick, if the issue is a ground one. The only other thing it really could be is the transmission range sensor itself, which is not as easliy dealt with.
Thanks for the info and the pics.
