Still Having Problem With Dash
I was having issues with my dash, door locks and AC go on and off rapidly and by itself. After hearing from everyone else it seemed i needed to replaced my battery. Ok so i replaced my battery with the Best one Sams Club offered that fit my jeep and the problem has actually gotten worse and more frequent and my battery light still goes off. I even charged the battery to full before running it in the jeep.
Now what do you think is wrong??
Thanks!
Thanks!
Make sure your battery connections are tight. If you can rotate them with your hand they're loose. Don't put any accessory wires under the nut closest to the battery terminal. It is a cam nut that tightens the connection.
Make sure your battery cables are not corroded through. Sometimes under the sheath near the cable ends the copper can completely oxidize, leaving very flaky connections.
