Stock wheel width ?
if look at tires in the 315/75/R17 range they will measure out to about a 35.
I use this tire conversion calculator a lot https://tiresize.com/calculator/ . Plug in your current tire size and it will tell you the height and width. Then you can start changing numbers to get what you want.
R/
Will
R/
Will
I have some Commander wheels and has some scratches on it. Cheep, but I see your are in the Bahamas. Same as a stock wheels that are 17". 35 x 12.5 x 17's look awesome on those wheels and I have seen 37's and not sure I would go that big.
315's are a lie.....no tire is measuring up to the advertised height. My 315/70-17 bfg's are advertised as 34.4" and they're a solid 33.5"--- brand new.
I'm between 33 3/4 to 34 mounted under the vehicle. 34.4" on the spare.
