Suspension loud over bumps
My 13 Sport S started out with normal spring rates (I don't remember) then to a TF coil lift which I took off and installed 18/60 springs.
Since installing 18/60 heavy duty springs it has been loud over larger bumps. I get a very loud thud over larger bumps.
Is this normal with heavy duty springs or is something going bad?
It's definitely not the bump stops. The suspension is essentially stock and it's not compressing nearly enough for bump stops to be involved. I'm curious if this metal on metal thud is a symptom of bad ball joints perhaps? Everything appears in place.....
im just throwing some stuff out here, but what about track bar bolts/holes? and play in any of the control arms/bushings? you can test bjs by jacking up the tire and grabbing the top and bottom and seeing if you can notice any play.
My suggestion would be to clamp a GoPro under your Rig and aim it where you think the sounds coming from..See how your suspension is reacting to the bumps..
