Sway bar help
Old 08-19-2014, 04:08 PM
williamsc75's Avatar
Default Sway bar help
I put a 2 inch body lift on my 08. Are the stock sway bars good enough or should I upgrade? If so, which ones r the best?
Thanks
Old 08-19-2014, 06:34 PM
Grand Umpah's Avatar
I wouldn't think that a body-only lift would require a different sway bar link; you aren't increasing the distance between the frame and the axles.
Old 08-19-2014, 07:54 PM
TheDirtman's Avatar
The sway bar is connected to the frame and axles not the body. The body lift would require no adjustments to the suspension.
Old 08-20-2014, 02:23 AM
Thanks guys. Appreciate it.
Old 08-20-2014, 04:57 AM
kjeeper10's Avatar
A body lift or spacer lift ?
2007 Rubicon /2 door/6 speed
Quick Reply: Sway bar help
