synergy draglink
Old 04-07-2015, 04:30 AM
TheDirtman's Avatar
^ Yep, they also have some low misalignment boots that will limit the droop in the TRE that is good to use when you are in a stock position.
SYNERGY MANUFACTURING :: Jeep JK :: Synergy Jeep JK Low Misalignment TRE Dust Boots
Old 04-07-2015, 05:06 AM
jnabird333's Avatar
SYNERGY MANUFACTURING*::*Jeep JK*::*Synergy Jeep JK Low Misalignment TRE Dust Boots
I tried these on the wife's Jeep and they work well for the tie rod, but not so much on the d-link. When you droop one side will open and let crud in.
Old 04-07-2015, 05:14 AM
TheDirtman's Avatar
Thats why they are "low misalignment", they are not meant to be used on vehicles that have lots of articulation.
Old 04-07-2015, 05:29 AM
jnabird333's Avatar
HaHaHa.... I know I was in a pinch and it was the only boot I had. IMO the d-link is not a low misalignment application even on a stock rig though.
Old 04-07-2015, 05:36 AM
TheDirtman's Avatar
IF you don't hit the trails it would be. From the photos it looks like the op just runs on the pavement or dirt roads at worst. I would not recommend running the low misalignment boot on a rig that is run off road and needs the articulation.
Old 04-07-2015, 08:12 AM
AirJordan613's Avatar
I had this exact problem. The jam nut can be loosened and the drag link can be rotated up.
Old 04-07-2015, 09:36 AM
blacklock's Avatar
I will try loosening it and rotating it up away from the tierod. See if I can get it to stay in that position. Thanks for the input.
Old 04-07-2015, 07:42 PM
sea bass's Avatar
I planned on installing them on my Synergy TR because they recommend them for hydro assist. Is there a drawback to running them on the TR as far as binding under full stuff? I understand the issues on the draglink but I was hoping there wouldn't be any issues on a TR.
Old 04-16-2015, 08:14 PM
Justinn407's Avatar
Here's mine, no issues...
Old 04-17-2015, 04:24 PM
sea bass's Avatar
Very nice. What ram setup are you using?
Quick Reply: synergy draglink
