Synergy Tie Rod Ends and Stock Tie Rod?
My left end is worn out. I'm planning on getting a pair of Synergy ends but wanted to make sure it worked fine with the OEM tie rod. Ends are $30 each and the really nice Synergy Rod and Ends are $325 (Northridge). My stock tie rod is fine so I thought I'd just get the ends. Is the threading and size going to match up? Would I be much better off spending the extra $260 on the full kit?
TIA!
TIA!
If you go off road on anything much more than dirt roads, the tie rod and drag link are pretty vulnerable to being bent. I've seen several bent. Recommend replace with a quality product like Synergy. If you don't off road, recommend you check with Northridge on whether parts will work as you want. They are the ones who will need to take them back if you decide that isn't a good approach. :-)
I've seen the stock tie rod ends removed, so I tried to do the same thing you want to do. I could not get the tie rod end off and ended up just getting the synergy bar.
