Threw a Rod. Replace engine or bail out?
If you are the original owner you're covered under lifetime power train warranty provided you had all the factory recommended maintenance services completed. These engines hold together if they're maintained and not run low on oil or coolant. They will spin rod bearings easily if run low on oil, that's what your dealer is assuming. Hold their feet to the fire.
Good luck with whichever road you choose!
Each part is just under 20 minutes
PART 1
Hemi JK: V6 to V8 Swap | Truck Tech | PowerNation TV - Full Episodes
PART 2
Hemi JK: V8 Swap Completion | Truck Tech | PowerNation TV - Full Episodes
PART 3
Hemi JK: Mid-Arm Articulation | Truck Tech | PowerNation TV - Full Episodes
PART 4
Hemi JK: Rock Ready | Truck Tech | PowerNation TV - Full Episodes
PART 5
Hemi JK: Payoff | Truck Tech | PowerNation TV - Full Episodes
Thanks everybody! I decided to have a local shop put in a Jasper remanufactured engine. It's a little more than what I could have found a used motor, but I figure at least I have a warranty. Used just makes me nervous, never know what you'll get.
So I guess I'll be back on the road in about a week or so. Lessons learned.
I suggest that you do an internet search on something like Jasper engines reviews to see whether they do a good job. Remember that they and other bulk rebuilders have to use the core engines they receive and because the price point is important, they have to re-use as much as they can of the used stuff.
I've had bad luck with the jasper rebuilds in the past. The rear main seal has leaked on 3 of the 4 motors I got from them. Number 4 is a rebuild and it's still in the garage. They are supposed to clean up the block and there was a piece of a head bolt left down inside the block when I got it back. It's a rare motor to where I got the one back that I sent in.
So watch the rear main for leaks.
Same thing happened last summer to my '07 with 53k on it. Dealer said no oil, looked like it had never been changed. BS! I had even checked the oil 50 miles earlier. I was on vacation and didn't want to deal with it so I traded it in, but that engine was crap and because it was pre-Fiat it had no extended warranty.
