Time (not mileage) intervals between engine oil change
Hi,
I accumulate quite a low mileage on my Jeep (2011 Rubi) as my commute to work is very short (lucky ). So I am not reaching recommended mileage for oil changes (be it 3K or 4K miles) even within 6 months. Should I wait to reach the recommended mileage or go ahead and change every 6 months? Or maybe less than 6 months ?
thanks!
thanks!
Hi,
thanks!
thanks!
Im in the same boat. I change in spring and again in fall. I have always done that even when I put more miles on then I do now. Now I work from home and do 50ish miles a week with shopping and stuff.
Does your OCI warn you to change oil?
The manufacturer recommends following the OCI but never to exceed the mile/time period.
Not true, there is no setting either miles or time-wise. There is a complicated proprietary algorithm that computes multiple parameters discussed in other threads. The 8,000 miles (6,000 in older models) and 6-month periods are the extreme end of the drain interval range allowed for warranty purposes.
You are absolutely correct.
Sorry, I posted misinformation.
In any event, the JK's have an oil change indicator warning/reminder light, which is based upon the algorithim.
