Towing a bass boat with jku
I have a 2011 jku rubicon 3.8 it has 4:10 gears front and rear w/33's 2.5 teraflex spring lift. will I have any problems towing a 18' bass boat single axel trailer total weight about 3400 lb? Thanks
With 4.10's I don't see any reason you should. Might be a little anemic, as it's the crappy 3.8L minivan motor, but you should still be able to do it no problem.
You should be able to tow it without a problem. However, I highly recommend that the trailer have brakes wired to a brake controller in your jeep. I have a 2012 JKU with 3.73 rear and successfully towed a 5000 pound trailer shaped like a box.
I have an 08 auto, and tow an 18' open bow ski boat all the time. Also done several 12+ hour trips with either the boat or a fully loaded 6x12 uhaul up and down between Texas and Colorado. No brake controller, just the factory tow package with hitch and harness. Done it with 3.73 and 33's, 5.13 and 35's, and 5.38 with 37's. The trailer has 16 year old surge brakes, not electric. I did add a trans cooler.
Other than the total lack of getty-up, no issues at all. Just slow and steady, and choosing when to push the od/off button. The boat is a much easier tow - I would guess because of the aerodynamics as compared to the boxy trailer? Just take it easy and you won't have any problems.
I have the same rig (2011, 3.8, 4:10 etc.) and I pull several different trailers and the only complaint is anemic power. Plan on turning off the O/D for hill country. Oh and plan on spending twice as much for gas. But you really should not have any major problems.
I don't know if this can help anyone with the 3.8 but I recently removed the muffler and threw on an inine glass pack. I guess it could just be my imagination but my Jeep seems to accelerate much faster and easier.
The max legal towable with a JKU is only 3500lbs, so very little wiggle room.
This has been discussed on this forum and others ad nauseam.
Don't put yourself and others at risk towing over the vehicle's limit.
The vehicle was designed and claimed by FCA to have a capacity of 3500 lbs for towing. If a driver knowingly exceeded that capacity and had an accident, you could lose your ass in a negligence claim. This has been discussed on this forum and others ad nauseam. Don't put yourself and others at risk towing over the vehicle's limit.
