Yakima Bike Hitch Rack Interferes with Spare Tire
I've got a Yakima Hitch Bike rack that fits when the tail gate is closed and is supposed to be able to fold down allowing access to the rear tailgate however the spare tire is about an inch too low and even with the rack folded down, it still hits the bike rack. Will a Spare Tire Carrier solve this issue? I see a lot of adapters meant to hold bigger tires that will shift the spare up and out a bit. Is this a good idea/way to solve this problem? I've got a 2011 rubi JKU if that makes a difference.
Which rack do you have? I'm looking at getting the double down 4 bike rack and I'm not sure if it will clear the spare. Would a hitch extender do the trick? Let me know if you ended up finding a resolution. I don't want to go with the spare tire rack due to weight and I will need to carry up to four snowboards at times.
I have an old version of the doubledown. The extender may work but my thought was that it would push out the carrier too far so I opted for a tire spacer that lifts the rear tire on the stock carrier by an inch or so. I haven't tried it yet but I'm hoping this solves the problem.
I would really lie one of these bust as stated in this thread i am also on a stock carrier and am worried about the weight...
I had the same issue with my my spare tire hitting my hitch rack, Thule model that folded down. A extension only pushes it out further from the spare, still can't open the tailgate when folded. Ended up buying a new rack, Thule swing away model was the only one that would clear the spare tire. Stock spare tire on a 2011 rubicon.
I have a Thule Hitch mounted rack that I encountered the same problem with. My solution was a 1 foot hitch extender. It puts the rack out pretty far behind the Jeep but does allow use of the tailgate. Considering bikes are pretty light I dont think the extra leverage could cause any issues. Its not like we are towing a boat.
