Traction Light, ABS Light, ESP BAS Light On - Having trouble troubleshooting.......
The codes are in.....
C102A
C1027
U1417
Seems like everything having to do with the left side. C102A is the left rear. C1027 is the front left ABS module but also lists left rear. U1417 is Implausible Left Wheel Distance Received.
C102A
C1027
U1417
Resolved. Drivers side rear wheel sensor. Christmas lights went out after driving 30 feet. Just an FYI, I bought what I thought was a non OEM wheel sensor and saved $5 in the process through Amazon. Search for Standard Motor Products ALS1932 ABS Wheel Speed Sensor. When I opened the generic box, inside was a plastic wrapped Mopar part!!!! I am still seeing the ABS codes through the fancy scanner but I believe the Jeep needs to cycle on off a few times before they clear completely.
Thanks again for everyone's help!!! I hope this thread is informative to others.
I am going to throw this in because it makes absolutely no sense but I had the same lights on my Dash. Took a look and nothing looked out of the ordinary. Checked the bearings and they were fine. The only thing I noticed that was wrong with the whole Jeep was the passenger front fog light was burnt out. Well I didn't want to replace the bulb with a factory one so I got some after market lights and after I got them installed, the warning lights on the dash went away and never came on again. Coincidence I don't know but it worked.
