Handles
FYI, before u make your decision on the synergy bars be sure to look at the installation instructions. They are quite a bit of work and does require some plastic cutting. However if done right they do look better(actually looks stock) then the grabars. I went with the grabars for the easier install, didn't wanna cut the pillers. Think u will be happy with either, good luck with your decision!
Check out JK-RIGRIP on ebay. I'm quite happy with mine. No drilling or cutting required. They are extremely sturdy. I can shake the jeep without any movement from the handles.
I have the synergy handles and am really happy with them. They require a tall notch in the pillar plastic, in stead I drilled out a large enough hole to get the bars through. Very clean look and real stout
Attachment 532340
Attachment 532340
The handles should be the same for all JKs regardless of year, unless there were changes to the A-pillars that I am unaware of..
