Iron Eagle Built By Rebel Off Road
Former Vendor
Rebel Off Road exclusive Teraflex long
arm upgrade for Recon Coilover Conversion Kit
includes:
- 8 arm upgrade
- drag link flip kit
- front track bar
- rear brack bar
- weld on long arm brackets
- brake lines
Dana 60 front Rock Jock axle - Currie
- ARB air locker
- custom width for 40 inch tires
- f450 knuckles
- heavy duty tie rod
- 4:88 gears
- master install kit w/ bearings
- all brackets included
- 1350 yokes
- 6 on 5.5 bolt pattern
- differential cover
Dana 60 rear Rock Jock axle - Currie (full
floater)
- custom with for 40 inch tires
- hubs / yoke / drive flanges
- 35 spline axles (super heavy duty)
- ARB air locker (35 spline)
- 4:88 gears
- master bearing kit
- brackets (upper/ lower control arms)
- brackets (track bar etc.)
-1350 yokes
ARB air compressor
Recon front coilover mounts for 12" 2.0 /
2.5 coilovers
Recon King coilover 2.5 12" Rebel spec
proprietary valving
Recon King coilover 2.5 14" Rebel spec
(rear only)
proprietary valving
Recon rear bolt-on 14" coilover mounts
Recon front bolt-on hydraulic bump
stop mounts
Recon King air bumpstop 2.0 4" (limited to
2") - black finish
Rebel Off Road - rear hydraulic bump
stop kit (weld in)
JE Reel 1350 heavy duty driveshafts
Ripp JK Supercharger 3.6l
Borla Climber exhaust system
Wild Boar Off Road 2 way Air System
Warn Zeon 8-s winch
-synthetic line
Factor 55 Prolink
Poison Spyder winch fairlead mount
sPOD wiring management system
-with air gauge
Rigid Industries SR Series 50" lightbar
Rigid Industries Dually D2 pair
Rigid Industries LED rock light kit (6)
AEV Procal
Raceline 17" 231 beadlock wheel
Toyo Open Country M/T 37x13.50x17
Currie Anti Rock rear
GenRight Off Road aluminum tire carrier
Poison Spyder RockBrawler 2 rear
bumper
Poison Spyder LED backup lights
Rebel Off Road-Restraint Complete Brake
Kit (Dana 60)
kit includes:
- 2x restraint front rotors (double
drilled & slotted)
- 2x restraint rear rotors (double
drilled & slotted)
- 1 set of front pads
- 1 set of rear pads
Poison Spyder license plate light
Testing King steering stabilizer
Dominion steering stabilizer relocation
includes:
- 8 arm upgrade
- front track bar
- rear brack bar
- brake lines
- ARB air locker
- f450 knuckles
- 4:88 gears
- 1350 yokes
floater)
- 4:88 gears
-1350 yokes
ARB air compressor
2.5 coilovers
proprietary valving
(rear only)
proprietary valving
stop mounts
2") - black finish
stop kit (weld in)
Warn Zeon 8-s winch
-synthetic line
Factor 55 Prolink
-with air gauge
AEV Procal
bumper
Kit (Dana 60)
kit includes:
drilled & slotted)
drilled & slotted)
That's sick looking!! You guy have been hitting out the park with this build and the katacon build also. Do you have the part # for the lift kits that you used from Tera flex?
So is this the standard build coming out of the shop now? It would be nice to see more variety (aside from colored suspension components) in the parts.......but I guess as long as you've got folks dropping off checks for $55k, why not??
What was the driving force behind doing 6 lug axles on this as opposed to the standard 5*5.5"?
Former Vendor
My build is a bastard kit of random parts, it's a great daily driver. I'm all in at less than what most people pay for just the truck. 140k super satisfied miles here.
Kudos that what you're doing is working well for you. Bond has got to be thrilled that you've dialed in the prefect combo.
Awesome build!! I love the Recon coil over kit. I know several people running it and once dialed in performs big time! You guys need to open a shop on the east coast, say Raleigh!!
