5 Best Replacement Soft Tops
Has the soft top on your Jeep seen better days? Are you sick and tired of all sorts of things invading your cabin to remind you of the sad state of your roof, or lack thereof? Check out these options to get things nice and cozy again for your Jeep.
1. Bestop Sailcloth
There are a ton of enthusiasts that recommended this top as the be all end all for your Jeep's roof replacement. Owners cite that the top is much quieter than the OEM top they had and thus more friendly to everyday life when you want to hear your music or conversation while on the road. Bestop is also the company that makes all of the soft tops for Jeep so you know that you're getting quality materials. The price on this one is a bit steep but the quaslity that comes with it is number 1 in the minds of many Jeep owners.
>>Join the conversation about the Best Replacement Soft Tops right here in the JK Forum!
2. Viking Soft top
For another OEM like replacement top, enthusiasts also say that Viking is a brand worth your time. Owners say that it's a nice top that is made from the same materials that Bestop uses for the sailcloth designation. The Viking model eliminates all the bowed and folding that goes into removing a top since it lacks a frame. While removing the top will be quick and effortless, you may not want to do it very often as some say the Safari mode let in way too much sun that ended up beating them into exhaustion.
3. Pavement Ends
Another factory style replacement that has tinted windows and upper doors on it, Pavement Ends provides a not too pricey option for Jeep owners. The positives on this top are that gives a nice tight fit that is easy on the eyes and just as easy to install. Users said they don't really experience any flapping while driving and that they enjoy the tight seal on the tinted windows to keep rain out. However, the windows themselves feel thin and under heat seem to shrink a bit making closing the area tough.
4. Mopar
If you can get your hands on a top from a Sunrider or a Rubicon then you can rest assured that you have a quality part straight from the factory. The pros on these, of course, is that the seal and fitment are excellent while letting passengers enjoy a quiet and warm ride. The window zippers are a bit hard to get started since the material is very thick. If you have any mechanical lube it is recommended to add a bit to make zipping a breeze. Check out eBay and Craigslist to find some factory replacement tops fo your Jeep.
5. Bestop Trektop NX
Everything you need for the install of the Trektop NX comes right in the package so as to save you time and keep you from install frustrations. Once the top is on you'll enjoy a great sleek look that harkens to fastback profiles that are saved for sporty vehicles. It is easy to remove the windows on this model so enjoying summer breezes will be a quick and enjoyable task. Unfortunately, when it is time to put those windows back, the install can be a bit tricky. Once enthusiast remarked that he pulled on the rear strap a bit too hard and that holds to the tub and tore a 4-inch rear window channel pout of the top! If you believe patience is a virtue as far as window installations, then this top has your name written all over it.
For help keeping your JK Wrangler rolling free, check out the how-to sections of JK-Forum.com
