Top 5 Tips for Off-Roading in Your Wrangler
Heading out to tackle some trails in your Jeep? Here are the top 5 tips for off-roading in your Wrangler.
1. Take a Friend
Never, ever head out off-roading alone. A buddy can call for help if you get in a predicament, which is much more likely to happen off-road than on. Plus, he can jump out and serve as a spotter so that you don't get stuck trying to ford a river too deep or climb a rock too tall. Best of all, your buddy can share in all the fun that off-roading has to offer.
>>Join the conversation about the top tips for off-roading here in JK-Forum.
2. Know Your Wrangler
Take the time to read through your owner's manual and understand all the controls in your Wrangler, especially if it's new to you or if it's your first time off-roading in it. Know how to engage and disengage four wheel drive and what the different driving modes do. Also, check your ground clearance and be aware of your Wrangler's basic capabilities before you hit the trails.
3. Research Your destination
Be sure and do some basic research on where you're going. Don't try to tackle a trail that is above your skill level, or one that your Wrangler isn't capable of taking on. When you're out on the trail, don't try to blow through water without checking to see how deep it is first. Check the weather for the day you are going and the next day and night, just in case you get stuck.
4. Make Some Checklists
Before you head out, make a few checklists so you don't forget anything. One of them should be for supplies such as survival goods, extra clothing, basic medical supplies, food, and water. Another should cover all the tools you might need, including a jack and strap if nothing else. Lastly, make a checklist for your Wrangler to ensure it's in tip-top shape before heading out. Check your tires, fluids, and lights above all.
5. Alter Your Driving
Driving off-road isn't the same as driving on-road, and you'll need to alter your driving style a little. The best way to go is to maintain a slow but steady pace. Your momentum will keep you going through and over most obstacles. If you get stuck, don't sit there and desperately spin your wheels hoping to get free, as you'll only dig yourself deeper into the hole. Try to slowly back up, then move forward a few times before looking for a tow. When driving up a tall hill, keep the transmission in a lower gear, and use a higher gear when heading down a hill. And approach large obstacles at a 45-degree angle so you can keep three wheels on the ground at all times!
For more information on off-roading click here, and for how-to guides on maintenance and repairs, scroll through our articles here in JK-Forum.com!
