Rotating banners with links
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: Fuel Pump screwing up my CB reception.
  1. #1
    JK Super Freak dmhines's Avatar
    Join Date
    Apr 2009
    Location
    Forsyth County, GA
    Posts
    1,110
    Default Fuel Pump screwing up my CB reception.
    With engine off reception is nice and clean. When I turn key to start I get a couple of seconds of interference. With engine running it's constant interference. I figure it must be the fuel pump.
    I'm thinking of getting some ground straps and grounding battery to body and frame to exhaust.
    I also found this thread about making an RF blocker for the fuel pump:
    http://97vette.com/sporttrac/rfi_fix/rfi_fix.html
    I have my antenna grounded to bolt holding subwoofer in just like Cooltech instructions say.
    Any other suggestions?
    Jeep JK MAVERICON:
    33" MTZ's on Eagle Alloys - Deep Water Blue - Manual Tranny - Half Doors - Rubi E-Disco - RR Evap Skid
    JKU Rubi Suspension - Custom MAVERICON Bumpers - Warn XD9000I - XRC Rock Rails - 4.88:1 G2 Gears
  2. #2
    JK Enthusiast JKGuy's Avatar
    Join Date
    Jul 2007
    Location
    Los Angeles
    Posts
    159
    Default Coax
    You might find it easier to just re-route the coax. Sometimes all it takes is moving it a little bit to solve the problem. I ran mine from the right rear bumper to the roll bar and then forward. I can hear a tiny bit of engine noise if I dump the squelch but thats about all.
    My power is also run from the battery to the radio with a torrid coil on the power line under the dash.
  3. #3
    Join Date
    Apr 2009
    Location
    Forsyth County, GA
    Posts
    1,110
    My Coax is also routed up and across the right side roll bar.
    I ordered another coax that looks more shielded than the thing black firestik Coax with the firering. I'll play around with the routing of the new coax and see if it makes a difference. I need to go to Fry's tomorrow and see if I can pick up ferrite rings and redo my power. I do have i connected directly to the battery.
    I do notice that if I actually hold onto the top of the antenna with my hand that all interference goes away ... wonder what that means? It is a Firestick II.
    Thanks ... Dan
    Jeep JK MAVERICON:
  4. #4
    JK Junkie GoodysGotaCuda's Avatar
    Join Date
    May 2009
    Location
    Denton, TX
    Posts
    3,200
    You touching the antenna throws the whole system pretty haywire. Doesn't really do anything towards diagnosing the problem. Make sure the radio has a strong ground, as well as the antenna/mount. Grounding is the most common cause for RFI.
    2009 Rubicon - 6spd
    5000k HID head and off-road lights|Cobra CB|Hi-Lift|20# Co2 Setup|LED Rock lights| Daystar Panel| Grille Mod| RC 2.5" spacer kit|35" KM2's | Chopped Flares | C-gussets | Superchips Tuner| Riddler Diff Covers| OR-Fab front sport cage| Poison Spyder BFH - Comp bumper|
    I need a winch...
  5. #5
    Join Date
    Jul 2007
    Location
    Los Angeles
    Posts
    159
    Default Grounding
    Sounds like maybe the antenna mount isn't grounded well. If you are using a spare tire mount then it's important to scrap the powder coat away on the bottom of the mount to ensure it's grounding.
    I have an XHD rear bumper and just got tired of messing with it so I mounted a ball mount on the top of the bumper (serious ground) and ran the coax through into the tub and up the roll bar. I've never been too convinced of those spare tire mounts.
  6. #6
    Join Date
    Apr 2009
    Location
    Forsyth County, GA
    Posts
    1,110
    Quote Originally Posted by JKGuy View Post
    I'm using the COOLTECH stainless gate mount. I ran the ground wire to the SubWoofer bolt as per the instructions.
    I'll have to play around some more with the ground. I'll run a temp ground from the antenna ground directly to the frame and see if it makes a difference.
    Jeep JK MAVERICON:
  7. #7
    JK Freak donnie's Avatar
    Join Date
    May 2009
    Location
    Simi Valley, Ca.
    Posts
    669
    FWIW, Im using the CoolTek tail light mount and routed the coax under the carpet on the left side to the cb.
    So far, I havent noticed any interference other than the normal stuff with the cb.
    09 Sahara Unlimited 4 dr
    Sunburst Pearl Orange
    4 spd auto
    Freedom Hardtop
    Class of '09 driven by Class of '48
    More parts added as soon as
    money tree blooms.
    JEEP-ism is a disease and there is no known cure
    CoolTec Cb antenna mount w/4'antenna
    Cobra 18 WST
    Yaesu VX6 HT
    Diamond K 412 SNMO
    Larson 2/70
    Dirty Dog Sun Screen
    ARR Radio Bar
    donnie
    KC6CME
    73
    http://www.northridge4x4.com
  8. #8
    JK Super Freak JdTms11's Avatar
    Join Date
    Dec 2007
    Location
    Wellesley, MA/ W. Hartford, CT
    Posts
    1,328
    where is your CB grounded to. i had mine grounded to the firewall and was having allot of interference issues, guy and a CB shop told me to just go directly to the battery and that along with a strong chassis ground for the antenna mount eliminated all of the feedback i was getting.
    Mods
    07 unlim. X
    BLACK
    Skyjacker 2.5 BB ~ DAYSTAR 3/4" F spacers
    35" BFG KM2s ~ 15" Crager 397's
    River Raider snorkel ~ Cooltech exhaust
    5' firstik II ~ 6" kc slimlite ~ Warn M8000
    LoD shorty w/ stinger
    ~ LoD sliders~ LoD Shorty Rear/ carrier~ Fender Chop
  9. #9
    Join Date
    Apr 2009
    Location
    Forsyth County, GA
    Posts
    1,110
    My Cooltech is the gate mount so running it up the left side would not be an option with 18' coax.
    My antenna ground is to the body ... not the frame. I'm gonna play around with better ground solutions as well and see how it works out.
    Thanks all ..... Dan
    Jeep JK MAVERICON:
  10. #10
    JK Super Freak whpony96's Avatar
    Join Date
    Feb 2008
    Location
    Nampa, Idaho
    Posts
    1,521
    Quote Originally Posted by dmhines View Post
    You need to grind off the paint around the bolt that holds the subwoofer on or you will not get a good ground!
    08 Rubi Ultd | Teraflex 3" Lift Kit & Frt Trk Bar | 16" PC 1079 and 35" GY MT\R Kevlar's | Cobra 75 w/ Cool Tech mnt. | Mopar Htd Seats | "Rescue" badges | Flashpaq w\ XDI CAI | Woods Hood Lift & Rear Door Shock & SS reloc kit | Gibson Quad Tip SS | MyGIG Lockpick & Multi Cable w\Mic & RV cam | True HID Bi-Xenon Headlights and Fogs 8000K | Viair HD Onboard Air | Riddler F\R Diff Cvrs | Changed all bulbs to LEDs
    Wife that works on the JK with me..
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
