Rotating banners with links
+ Reply to Thread
Results 1 to 4 of 4
Thread: Question regarding wiring Cb to power supply
Threaded View
  1. #1
    JK Enthusiast WestGaParrotHead's Avatar
    Join Date
    Jul 2007
    Posts
    187
    Default Question regarding wiring Cb to power supply
    I've got a Cobra 18WXST-2 CB and off the back of the unit where the power wires are located, there are 3 wires Blk (ground), Red (pos main power) and an orange wire.
    Now the power and Orange wire are Fused with a 4amp fuse (each).
    according to the instructions the red connects to a constant power supply, while the orange connects to a power supply that cuts off when the ignition is killed. My question is do I have to go this route? I'd prefer to have constant power going to the CB , and just turn off the unit when it's not in use (not to mention I really dont want to pull the dash apart just to splice into one of the 12v accesory outlets...
    according to the CB writeup, the cb was wired to the battery and fused... but seing how this unit uses what appears to be along the lines of 16-20 gauge wire and a 4 amp fuse, and the unit in the writeup used 14gauge wire which is rated for higher amps, what do I need to do... I really dont feel like popping those 4A fuses on a regular basis seeing how they will be behind the windshield trim panel...
    Any and all info will be greatly appreciated.
    Phinz Up
    2007 Silver X 2 Door
    Dana 44 w/ 4.10's 6 Speed
    ΜΟΛΩΝ ΛΑΒΕ
  2. #2
    Join Date
    Jul 2007
    Posts
    187
    Bump..... Anyone?
    Phinz Up
    ΜΟΛΩΝ ΛΑΒΕ
  3. #3
    Sponsoring Manufacturer
    Join Date
    Sep 2006
    Posts
    260
    You'll be fine to put these wire together and go straight to the battery or a 12 source. Keep the fuses on both lines - there's no way it will pull more than 4 amps cumulative.
    The Best Antenna Mount for the JK
    www.cooltechllc.com
  4. #4
    Join Date
    Dec 2006
    Location
    Grand Rapids, MI
    Posts
    73
    Taking the dash apart isn't that hard at all. Also, you will have both a switched and constant power source if you tap into the 12 volt power and lighter outlets in the bottom of the dash console.
    2007 Rescue Green Rubicon Unlimited
    3" TeraFlex Lift
    TeraFlex Front Trackbar
    TeraFlex FlexArms
    Spidertrax Spacers
    35" BFG Mud Terrain KM2
    UltraMount CB Mount
    Cobra 75wxst CB
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
