Rotating banners with links
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 17
Thread: Combo Scanner/CB with detachable faceplate
  1. #1
    JK Newbie mbanik's Avatar
    Join Date
    Feb 2007
    Location
    Boston
    Posts
    38
    Default Combo Scanner/CB with detachable faceplate
    Sounds like a tall order, no? Well Uniden makes the UH015sx for the New Zealand and Australian markets. Word from Uniden USA is "No, we don't sell that in the US" ... which is exactly what I expected them to say. This thing is slick IMHO...
    http://www.uniden.com.au/AUSTRALIA/p_uh015sx_index.asp
    some features...
    - Detachable Display Unit
    - Transmit & Receive FM 40CH (UHF-CB, TX Power 5W)
    - Wide Band Scanner (400MHz - 512MHz)
    - Band Search Function (5 Bands separately)
    - Duplex Capability (from CH01 - CH08)
    Where I am weak is the specs for the frequency ranges/bands ... are these ideal/compatible for the US of A? If so I would attempt to bring one over. I actually don't care too much if the scanner range is limited ... although it appears to be severely limited. What ranges/bands should I be looking for?
    Finally ... does anyone know of any alternatives out there?
  2. #2
    Senior Moderator JackMac4's Avatar
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Quote Originally Posted by mbanik View Post
    some features...
    nice! This would work well for my project. based on the description it sounds like it would work..but I'd be interested to know for sure.
    Help HappyCurmudgeon's Fight Against Cancer
    >>> Click here to make a Donation <<<
  3. #3
    Join Date
    Feb 2007
    Location
    Boston
    Posts
    38
    Default yes yes...
    Quote Originally Posted by JackMacOKC View Post
    I saw you thread and I thought of this unit... If I can't get something like this I will be going your route but I'll be using a Uniden Pro 520XL, a Bearcat BC350C and a Blaupunkt Hamburg MP57 ... I do not want navigation ... I still prefere a map and compass ... ha ha.
    The trick will be making the 520XL and BC350C removable for safe keeping ... a nice custom fab challenge... especially working in 2 channel mixer for the scanner / CB audio ...
  4. #4
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Yep..indeed a challenge. I still have a lot of ideas swirling around on how to handle the mixing. I've been looking around this evening for other cb/scanner combos but can't find any.
    I'm also looking at handheld scanners with DC input...thinking maybe I could tear one apart and build my own scanner.
  5. #5
    Join Date
    Feb 2007
    Location
    Boston
    Posts
    38
    Default mix
    nice ... another good route to consider ... repackaging electronics is a good time...
    I'm gonna work up a schematic for the mixer this week ... basically a simple DJ crossfader... full left is CB 100% ... full right is scanner 100% ... middle is 50/50. I think that will get it done...
  6. #6
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Yeah, it would but it wouldn't have to be that complicated..probably could do just a rocker switch with 2 mono inputs and 1 mono output
    maybe take the innards of something like this
    then you could integrate video srcs as well.
    edit: but then again, after thinking about it - the simplest way might be the best..so a mixer might really be the best way to handle that..then you could just mount a mixing knob.
  7. #7
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Quote Originally Posted by ******** View Post
    FYI, the frequency range of the scanner on the combo scanner CB listed above is pretty small. The range is also a pretty unused portion of the spectrum for here in the US. Even if you got it, you wouldn't hear a lot.
    There are some that have repackaged scanners for use in vehicles and you might want to check out www.radioreference.com for some hardcore scanner heads and some information on repackaging.
    I have several scanners but just got the new Uniden digital with 6,000 channels in 500 dynamic memory banks. I do wish the head was separate but I can make it work in it's stock form.
    I think there may already be some mixers for radios out on the market. May be easier and possibly cheaper than building your own. I haven't looked yet but I have heard of them and it's on my list.
    Cool site. thanks for the heads up. now i have a lot of reading to do.
  8. #8
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Wow. After reading that site, I feel like a dummy. There are a lot of people using newer systems than I thought. My tax dollars at work I suppose. This changes all my plans, as it seems most of the communication I would want to scan here is unscannable/encrypted.
    I'll just stick to a CB and FRS/GMRS
  9. #9
    Banned
    Join Date
    Feb 2007
    Posts
    465
    Wouldn't work, CB freqs here in the US center around 27mHz which is VHF, they list the unit as UHF. Also most larger cities run trunk systems for police and fire. Nice unit though, we never get the good stuff over here...why is that?
  10. #10
    Join Date
    Feb 2007
    Location
    Denver, CO
    Posts
    8,643
    Quote Originally Posted by John L View Post
    Yeah it doesn't, and I've been looking for something in the US...but I couldn't find a single thing -- most likely due to your above statement regarding trunking systems...just seems nowadays scanning is a bit too complex to stuff into a little unit.
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
