So I am in the middle of changing my differential fluid for the first time. I followed WOL's write-up, but since I have adjustable control arms and have changed my caster and pinion angles, I can't get as much oil in the diffs since the fill holes are lower. With the stock diff covers, D30 front and D44 rear, I am at 1 quart in the front and 1 3/4 quarts in the rear until oil starts coming out. Do I need to keep adding more? I was thinking about just adding it through the breathers, would that work? Any advice is appreciated. Thanks!
