I have a JK with INFINITY SYSTEM.
I want to keep FACTORY radio and install a mono Amp + 2-12" Subs.
DO I splice LOC after amp?
or DO I splice LOC into wires going to that 8" factory SUB?
NEED help!??
Thanks!
NEED help!??
Thanks!
2008 JK
Stone White 4-Door JEEP
D-Town aka DETROIT!
AND YES.....they're 22"s on my Jeep!
I put mine in a little nook directly under the radio. I didn't splice. I used suitcase connectors.
The difference between conservatives and liberals is conservatives believe some things are worth fighting and dying for. Liberals do not.
Rob
But which wire location??
AFTER factory Amp?
At Head Unit Harness?
Or Tie into Infinity SUBWOOFER at TRUNK??
2008 JK
D-Town aka DETROIT!
After the factory amp or at the subwoofer. It's actually the same thing, just different ends of the wire.
I doubt you want to splice the H/U output. The H/U puts out two flat audio channels to the amp. The amp splits those two and handles the balance, fade and other audio settings. If you tap at the H/U then your sub will only be at a set level. It won't go up or down with the volume.
Vern
______________
A P R S
Automatic Packet Reporting System
P is for PACKET!!!
