Sway Bar link suggestions
I need aftermarket front sway bar links for my 07 JK w/ a 2.5" BB lift. I just want a link that's 2.5" or 3" over stock & doesn't need to be a disconnect model.
Any suggestions as to which supplier to buy from (or stay away from)?
I'm assuming that would be the better way to do it being that the rear has no sway bar disconnects & the front does?
Would I be gaining anything by putting disconnecting sway bar links up front too if I already have the factory disconnecting system on the Rubi?
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
JK-Forum Founder
Believe me, I have looked and the limiting factor here is shock lenght. Also, any more droop and my drive shaft would make contact with the exhaust (I have a 6-speed/If you have an auto, your drive shaft would hit the skid way before you max out your droop).
I don't know about you, but how much more articulation do you need? This is my JK with the Rubi swaybar disconnected...
![](http://www.project-jk.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=20254)
![ROTFLMAO-1](https://www.jk-forum.com/forums/images/smilies/rotflmao5.gif)
07 2Dr Rube. I have a 3" TF lift. I bent a sway bar link extension. I'm thinking of using JKS PN2030 to replace the TF's. They are beefy & can be manually removed if necessary. Any comments? Thanks, Frank
