Quadratec
Go Back   JK-Forum.com - The Ultimate Jeep JK Wrangler Bulletin Board > Jeep JK Wrangler > JK Write-Ups
Thread Tools Display Modes
Old 11-01-2009, 08:13 PM   #241
NorthernILJEEP
NorthernILJEEP's Avatar
NorthernILJEEP is offline
Quote:
Originally Posted by joe002 View Post
That sounds like a good idea!
Nice pics - you planning on getting bigger tires too?
Thanks!
Ha, yes. Tires are the next item on my list. I kind of like the look of the stock Rubi Wheel/BFG combo. Also thinking about picking up an extra set of Sahara 18" rims and getting some bigger tires for them. Haven't decided yet
__________________
2009 Black Sahara Unlimited
2.5 TeraFlex Coil Lift
295/70/R18 Nitto Terra Grapplers
TeraFlex Rear Adjustable Trackbar
TeraFlex Front Adjustable Trackbar
Stainless Sill Protectors
Rugged Ridge Mats
Ipod/Iphone MyGig Adapter
MyGig Uconnect Mic
Projects soon to be tackled:
Hard Top Hoist (The one listed here: http://jk-forum.com/showthread.php?t=5559) - Halfway done. Just need to build the shelf.
TeraFlex Adjustable Control Arms
Old 11-01-2009, 08:23 PM   #242
joe002
joe002's Avatar
joe002 is offline
Quote:
Originally Posted by NorthernILJEEP View Post
Thanks!
Yeah, tire and wheel upgrades are a whole new thread, but I can show you my Jeep with the stock Rubicon wheels and tires:
And BFG 35s with AEV wheels:
It cost me a lot more to do the 32" to 35" tire upgrade then the 2.5" Spring Lift!
__________________
2008 Rubicon, 2 Door, Flame Red, Automatic, MyGIG, Power Group, Deep Tint
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Rear Stubby Bump, Currie F/R Adjustable Trac Bars, Daystar Upper Dash Panel, FireStick FireFly Antenna, Kilby Rear Shock Skids, LoD Sig Stubby Front Bump, Midland 75-822 CB, Mopar Filler Door and Locking Gas Cap, Rancho Control Arm Skid, Rancho Oil Pan Armor, Riddler Diff Covers, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relocation Kit, Yukon 5.38s
Old 11-02-2009, 06:41 AM   #243
NorthernILJEEP
That is a nice looking combo. The 35s really fill the wheel well nicely.
__________________
Rugged Ridge Mats
MyGig Uconnect Mic
Old 11-02-2009, 06:33 PM   #244
joe002
joe002's Avatar
joe002 is offline
Thanks, I agree. Since you said you were interested in BFGs with the lift I figured showing both could help your decision.
BTW - I sometime get a little rub in the plastic end cap on the rock rails when I flex out the rear hand hit a bump at the same time. The rubbing isn’t bad - typically less then a half turn of the tire. So far it hasn’t been annoying enough to adjust anything (like shorten the rail a half inch or so).
__________________
Old 11-03-2009, 12:31 AM   #245
d0wnShifT
d0wnShifT's Avatar
d0wnShifT is offline
Glad I found this post! I just got this lift and will be putting it on this Wednesday. I also got a JKS rear trackbar and was wondering if I should just use the stock trackbar mounting points or put the drop bracket supplied in the kit as well?
__________________
2007 Rubicon 2 door Red Rock
6 speed, hard top
Mopar front bumper with fogs and PureJeep shackles
Mopar rear bumper with tire carrier
Warn 9.5ti winch
IPF 968's
Teraflex 2.5" spring lift
JKS rear trackbar
Procomp 16x8 8128's
Goodyear MTR w/Kevlar 315/75/16
www.Northridge4x4.com
Old 11-03-2009, 11:11 AM   #246
beamme84
beamme84's Avatar
beamme84 is offline
Quote:
x2 on this question. I'll have both front and rear JKS trackbars.
__________________
09 2dr Flame Red X 6 Speed
18" Sahara Wheels and Bridgestone Dueler
[x] E55 Bi-Xenon Projector Headlights 4300K
[x] Teraflex 2.5" Coil w/9550 Shocks
[x] Spidertrax 1.5" Wheel Spacers
[x] JKS Front and Rear Track Bars
[ ] 33" GoodYear Duratracs on 16x8
[ ] 4.56 Gears
[ ] Mopar Offroad bumper
[ ] XRC8 Winch
Old 11-03-2009, 01:27 PM   #247
08RubiUnlimited
08RubiUnlimited's Avatar
08RubiUnlimited is online now
If you have adjustable track bars, then there's no need to use the bracket
__________________
Jeff
08 Rubicon Unlimited - Jeep Green, 2.5TF Spring lift, RR XHD front/rear. Rock Hard 4x4 skids all over, 4x4 evo f/r LCA skids, 285/70/17 BFG KM2, MyGig, both sets of doors and tops
Old 11-03-2009, 02:15 PM   #248
sjak
sjak is offline
Definitley use the front TB! A week after the lift install my front axle shifted 1-1/2" over and welcome to the world of Death Wobble.
You are doing it right and avoiding that fun experience. . . had to add a Full Traction front track bar to fix the problem (liked the TF better but needed an immediate fix. . the FT was in stock at Screaming Lizard).
Good luck with the install!
Old 11-03-2009, 06:30 PM   #249
joe002
joe002's Avatar
joe002 is offline
...I also got a JKS rear trackbar and was wondering if I should just use the stock trackbar mounting points or put the drop bracket supplied in the kit as well?
Well, the "best" setup would be a horizontal trac bar with the wheels perfectly centered. The adjustable trac bar permits you to perfectly center your wheels. The drop bracket makes your trac bar more horizontal. Both would potentially permit you to get both.
One issue you may have when using both could be that the adjustable trac bar may not be able to adjust in enough with a drop bracket. In other words, with the drop bracket you wheels could be almost centered with the stock trac bar and your adjustable trac bar may not be able to adjust down to the stock length.
__________________
Old 11-03-2009, 07:35 PM   #250
d0wnShifT
d0wnShifT's Avatar
Thanks for the reply. I see what you're saying with using both. I guess a good check for the adjustable trackbar is to try to match lengths with the stocker and if they're the same then I wouldn't have a problem.
My question is that is it really necessary for the rear trackbar to be near horizontal? I understand why having the front would be optimal to do but I didn't think the rear is all that important.
__________________
6 speed, hard top
Warn 9.5ti winch
IPF 968's
JKS rear trackbar
Procomp 16x8 8128's
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Viair
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
