RCV Performance
Go Back   JK-Forum.com - The Ultimate Jeep JK Wrangler Bulletin Board > Jeep JK Wrangler > Modified JK Tech
Thread Tools Display Modes
Old 11-03-2009, 01:59 PM   #11
RedneckJeep
Moderator
RedneckJeep's Avatar
RedneckJeep is offline
Quote:
Originally Posted by midwesterner View Post
Tank mounted to the tub just above rear axle, compressor mounted to cross member just behind rear axle. Custom control panel mounted in back. See pics.
Are you not afraid of compressor water damage?
__________________
It is enough that Jesus died and that he died for me.
Rob
www.Northridge4x4.com
Old 11-03-2009, 06:54 PM   #12
midwesterner
midwesterner's Avatar
midwesterner is offline
Quote:
The Viair compressor appears to be sealed up very well, I can't imagine any water getting in. The only weak spot I could see might be where the wiring enters the motor but it is sealed well. I have driven it thru a couple of fairly deep water crossings with no ill effects yet. Now if I let it sit submurged for a prolong period that may be a different story.
Anyone else have any issues with a compressor mounted like this?
Old 11-03-2009, 08:33 PM   #13
yellow08jk
yellow08jk is offline
How about where it draws in air? I'm guessing water could get in there. And if it kicked on while you were actually IN water...
Jim
Old 11-03-2009, 08:46 PM   #14
texmexjeeper
texmexjeeper's Avatar
texmexjeeper is offline
Quote:
Jim
was thinkin the same thing, may wanna move the intake line up behind the tail lights or some place like that up high.
__________________
08 UNLIMITED BRIGHT SILVER
17x9 Blacked Out Soft 8's
TOYO M/T 33's
SRC Front
SRC Rear w carrier
SB I-Rack carrier
LOD Sig Sliders
Warrior doors
Daystar hood latches
TF 3" lift w/TF Front HD adj. track bar
RH Evap skid
Solid dif covers
XRC 10 w/ SB synthetic line
poly roller fairlead
OBA
Hella 500 x 4
Optima Yellow top 34/78
AEV Snorkel w/ Ram
Sprayed rocker panels and hinges
+ much more
call Dave at
www.northridge4x4.com
he'll fix ya up
Old 11-03-2009, 08:50 PM   #15
w squared
w squared's Avatar
w squared is offline
Quote:
Originally Posted by azrockzuk View Post
compressor behind the passanger tail light ....
and river radier skid plate...
How do you bleed down the air tank and release the condensation when it's inside that skid plate?
I like the design, but that question just occured to me.
__________________
'08 Rubi Unlimited:
Custom front bumper
Warn 9.5ti
VisionX driving lights
3" OME/Currie/TF frankenlift
GhettoFab OBA system
A thick coat of Alberta mud
Old 11-03-2009, 09:53 PM   #16
midwesterner
Jim
No worries there; the intake is plumbed to a filter that is mounted behind the tail light.
Old 11-04-2009, 05:35 AM   #17
Schantin
Schantin's Avatar
Schantin is offline
That's a nice clean install.
__________________
http://www.jk-forum.com/picture.php?...pictureid=3800
2007 Jeep Rubicon Unlimited M6. Northridge OME lift, LittleSeat 3rd row, Warn 8000 winch, SpiderTraxx spacers, Airaid CAI, and some new Pro Comp 8069's with MT 35's.
2002 Camaro Z28 M6 heads/cam/etc....12s on street tires
1995 Chevy 3500 with a modded 454
2008 Hyundai Accent (piece of crap daily driver to keep everything else looking nice)
Old 11-04-2009, 10:55 AM   #18
yellow08jk
Groovy
Don't you like the SHTF smiley though?
Old 11-06-2009, 10:37 PM   #19
whpony96
whpony96's Avatar
whpony96 is offline
OK here's my setup..
First having the tank or compressor exposed to the elements was not a option. I did not want either to have the potential to get damaged by weather or off-roading. Second it could not take away from the amount of usable cargo interior space from the inside of the JK. And last of all it could not obstruct the ability for me to switch between the hard top and the soft or any functionality of either. So this is what I came up with....
__________________
08 Rubi Ultd Stone White
Teraflex 3" Lift Kit & Frt Trk Bar
16" PC 1079 and 35" GY MT\R Kevlar's
Cobra 75 w/ Cool Tech mnt.
Mopar Htd Seats
"Rescue" badges
Flashpaq w\ XDI CAI
Woods Hood Lift & Rear Door Shock & SS reloc kit
Gibson Quad Tip SS
MyGIG Lockpick & Multi Cable w\Mic & RV cam
True HID Bi-Xenon Headlights and Fogs 8000K
Viair HD Onboard Air
Oznium LED Rock Lights
Riddler F\R Diff Cvrs
Changed all bulbs to LEDS
Wife that works on it with me..
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Springtail Solutions
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
