Mountain Off-Road Enterprises
Go Back   JK-Forum.com - The Ultimate Jeep JK Wrangler Bulletin Board > Jeep JK Wrangler > JK Write-Ups
Thread Tools Display Modes
Old 11-13-2009, 08:32 AM   #271
joe002
joe002's Avatar
joe002 is offline
Quote:
Originally Posted by Northern Wrangler View Post
I have a question for anyone who's added this lift and since installed spacers to offset the sag from a heavier front bumper or winch.
Do you need to add brake line brackets or extended lines after adding a spacer to this lift? And do the rear brake line brackets allow for added spacers?
I don't know that you need to add spacers to the front for a heavy bumper and winch - I didn't. In fact, I had to add a spacer to the rear because the front would have been higher than the rear without the spacer. Do you have a 2 door of 4 door? You may want to try it first before automatically adding a spacer up front.
OTOH - even without a spacer up front, you may want to check your brake lines. I checked mine on a ramp and there was a little stress, but not much. On a friend of mines, who has a 2 door and the TeraFlex shocks, there was a good amount of stress on the lines at full flex.
The rear ones with the standard setup is fine.
If you start adding spacers beyond what comes with the kit you will be heading into 3"+ kit - which gets you into potentially looking at all of the extra items (arms, drive shaft, etc.).
__________________
2008 Rubicon, 2 Door, Flame Red, Automatic, MyGIG, Power Group, Deep Tint
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Rear Stubby Bump, Currie F/R Adjustable Trac Bars, Daystar Upper Dash Panel, FireStick FireFly Antenna, Kilby Rear Shock Skids, LoD Sig Stubby Front Bump, Midland 75-822 CB, Mopar Filler Door and Locking Gas Cap, Rancho Control Arm Skid, Rancho Oil Pan Armor, Riddler Diff Covers, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relocation Kit, Yukon 5.38s
Old 11-17-2009, 07:59 PM   #272
tuffluv
tuffluv's Avatar
tuffluv is offline
If my wheels have 4.25" backspacing, should I install the boltheads as Teraflex instructs or as you discussed at the beginning of this thread?
Old 11-17-2009, 08:21 PM   #273
joe002
joe002's Avatar
joe002 is offline
Quote:
I have 4.7" of backspacing in my wheels and have plenty of clearance to mount the links in the stock position. In theory with your wheels you should have even more room. If you have enough room I don't see any reason why you wouldn't mount them in the stock position.
I think the only benefit of mounting them differently is that you may be able to get away with the lift and stock wheels and no spacers.
__________________
teraflex 2.5 coil lift spring kit additional notes
Old 11-18-2009, 01:23 AM   #274
Texas Trailmaker
Texas Trailmaker's Avatar
Texas Trailmaker is offline
Default teraflex 2.5 coil lift spring kit additional notes
well, i just finished my 2.5 teraflex coil kit with shock adaptors install and took it in the back pasture for a test flex run.
im still using stock rubicon wheels and tires(32").
heard this awful noise and couldnt see what was causing it.
got back to the shop and the wheel inner lip had shaved the bolt head on the sway bar upper bolt at full tuck on the rear passenger side.
others have had this problem.
i did mount it correctly with the links on the inside of the swaybar(between the sway and the frame) and the nut was facing the frame.
i was hope'in that i wouldnt have to have spacers but that dream has been killed.
DAVID I NEED SPACERS STAT! i got wheeling to do saturday am.
hurry hurry
on a side note, the lift is awesome.
the jeep feels like it is waaaaayyyyyy taller that 3" from the driver seat going down the road. kinda has that -i could tip over really easy- feeling!
I LIKE IT
went it pretty quik once i rented some spring compressors for the front spring install.
i went from 34" in front and 35 3/8 rear to 37 3/4 front and rear. it completely leveled it out
my winch and aev front bumper with aev skid plate had really pulled down the factory front spings and the teraflex didnt even notice the weight!
ever since i installed the bumper and winch setup the steering wheel has been offcenter, now after the install it is off in the other direction the same amount. will fix that in the daylight, im tired. its 245 am here and i have had enough, still gotta work tomorrow.
the ride is stiffer to be sure but i like that too.....feels more jeepy.
__________________
09 Black JK Unlimited Rubicon
Dual Top w/Power Group
AEV Front Bumper & Skid Plate
8K Winch w/Roller Fairlead
Tuffy Radio Security Tray
Tuffy Rear Storage
Bonedigger's EVAP Skid Plate
WeGo4X4's Headrest & Radio Bar Grab Handles
RockHard Sports Cage w/Rear Center Brace & Padding
MyGIG Nav w/2.0 Software & Lockpick installed
Delta Skybar & IPF 968 lights for windshield+bumper
Northridge4x4.com
4WD.com
Leave NO ONE behind.
Old 11-18-2009, 06:36 PM   #275
joe002
joe002's Avatar
joe002 is offline
Texas Trailmaker - Yeah, if you can get it to work safely without spacers or wheels with the proper backspacing then I would consider you lucky. I think most people get spacers or wheels because the clearance without them is very tight.
Other than that, glad to hear all went well. Post a pic or two if you get a chance.
__________________
Old 11-18-2009, 09:31 PM   #276
sman
sman's Avatar
sman is offline
Ordered mine yesterday, installing next week. Great write-up
Old 11-18-2009, 09:56 PM   #277
joe002
joe002's Avatar
joe002 is offline
Quote:
Thanks. If you have any questions just post 'em up. There’s a lot of experience with the lift. Remember the instructions that come with the lift are a bit lacking, so read what you get and verify how the parts are to be installed and verify you got everything before you start. And don't forget to post some pics.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MBRP
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
