New! Soon to be Released 2012-Up JK Bolt-on Air System
Former Vendor
We have been working on this for some time now and are getting closer to final production. We will be offering a 100% bolt-in 2012-Up air system that utilizes a 3 aluminum gallon tank. Below is a first round drawing of what it will roughly look like. Keep in mind, this system will have a heavy duty bracket and be excessively beefed up to withstand impact. The image doesn't reflect this, but it has been through some changes that have re-inforced the bracket a lot. Also will have a built-in skid for the tank.
About 60 Days Until Production
Specs:
VIAIR 400C Compressor
3 Gallon aluminum air tank
Built-in relay for easy wiring
Remote mounted air couplers
Optional built-in regulator for air locker use
We will offer in a few different pressures all the way up to 200 PSI.
This kit will bolt underneath the Jeep in front of the factory Evap Canister mounting location. We will be test fitting soon, and I will post up pictures when we do.
Specs:
Woohoo! I can't wait I've been waiting for something like this n my 12. I knew it was only a matter of time. Will you keep us updated here? If so ill subscribe and keep an eye out.
Former Vendor
Yes, it should fit no problem, since this will go underneath along and bolt up in front of the evap canister.
We are still working on the final components that will be included. I think we will end up creating a few different options to choose from , depending on your intended use. Whether it be lockers, air tools, tires or all the above.
I am thinking it will be roughly around $499 price range depending on included components.
Former Vendor
You got it. More than likely we will run a special when the kit is first released. I will make sure to post details on that as well, in this thread.
