Turned OFF ESP WITH NO MODS
Here's on what I discovered. If you hold down the ESp button for about 10 seconds it turns off, but if you go from 4HI to 4LO it turns it back on Then you just hold down the button again. If you go from 2HI to 4HI it stays off. Hope this helps.
I haven't tried from to turn it off in 2 wheel drive at all but noticed it also turns back on when I go from 4lo to 4hi.
im fairly certain that this disables it MOSTLY...that is untill you get a lot of wheel spin (when you DONT want the tcs) it will kick in to "save" you
there is nintendo code that will turn it all the way off (something with the gas pedal and the steering wheel and the key....i dont rememebr who posted it but im pretty sure it works
Even with the ESP off the ELSD (Electronic limited silp) portion of the TCS (traction control system) will still try to brake a spinning wheel to force torque to the other side. And if you are going over 40mph, it automatically goes back to partial off instead of full off.
i don't think you should hear any clicking -- what i do think is weird is that it seems different from jeep to jeep -- i like to spin the tires in the mud and hit the ESP button all the time to do so, in two wheel drive and believe me its not partially on, i can shoot rooster tails all day with the push of a button, leave it on and it bogs down like crazy -- before i read the post on here i really thought it was ESP was for on road and you just hit the button for off-road -- and it stays off on mine in 4hi,4lo, and at any speed -- maybe my jeep has a problem with the ESP that i will not have fixed LOL
