Relocated Sub Box
Old 03-24-2007, 11:54 AM
DBB888's Avatar
Default Relocated Sub Box
Hey Guys
I was bored and was about to make brackets for my box because of the tailgate shock I put in so while looking at it I said what a waste of space.
Why not put it somewhere else. Then BAM- it hit me!!
Again I did this and if you follow and mess up- Well its on you.
I decided it would fit and look best here!
I cut all the brackets off First then filed them down and torched them so the color would be the same.
Tip- Torching plastic brings scratches and filing scars back to original color.
I found this bracket in my garage
Used this mounting bolt
Put the bracket on and put double sided tape on the box side
Press the box on and took the bolt out
Drilled and mounted the bracket
Extended the wire
Bolted down the box
Final Look
Old 03-24-2007, 05:56 PM
medsker's Avatar
Great idea, definately a must do for me.
Old 03-24-2007, 08:17 PM
BJeepJK's Avatar
What does it look like from the outside? It'll make takin the carpet out easier up there to.
Old 03-25-2007, 05:13 AM
DBB888's Avatar
Cant really see it through the tinted windows
Old 03-25-2007, 05:57 AM
Area-51's Avatar
Fine as long as you don't intend to ever take the hard top off.
If you do, that looks problemsome.
Old 03-25-2007, 06:51 AM
DBB888's Avatar
Whats the issue with taking the top off? I can still use the existing bolt to hold down the sub.
Old 03-25-2007, 04:25 PM
redWRANGLER's Avatar
how's the sound? Any vibration with that bracket?
Old 03-25-2007, 04:29 PM
DBB888's Avatar
Nope- solid as a rock
Old 03-25-2007, 04:36 PM
DBB888's Avatar
opps- Sound is the same
Old 03-25-2007, 06:33 PM
DBB888's Avatar
I dont think so- because when the soft top is down the rear fold should cover a portion of the lower box.
Still have hard top on so I can't tell yet.
Quick Reply: Relocated Sub Box
