Adding Custom Exhaust to Your Wrangler for Under $70
You don’t need to spend hundreds to give your Wrangler a throaty grumble.
An aftermarket exhaust system is a popular upgrade for the Jeep Wrangler, but for the amount of work involved and the power gains, a custom system or a full system ordered online can be very expensive. However, as forum member rfrogman points out in this great custom exhaust DIY write-up, you can get all of the benefits of an expensive exhaust system with a few changes to your stock setup – with the total cost being less than $70.
Introduction
When the OP first shared his Wrangler cat-back exhaust DIY, he started by giving us a simple introduction with prices and the parts needed, along with a list of the tools that you will need for the project.
“This modification uses one Summit Racing glasspack muffler ($21.95) and two Walker mega – clamps ($13.99 each) to produce an inexpensive Cat-back style performance exhaust without having to weld. It is very easy to do and can be done in your driveway.
Modification time: 1 hour
Tools required:
15 mm socket
5/8 inch socket
Socket wrench
Torque wrench
Breaker bar
Sawzall with metal cutting bladeParts required:
Glasspak muffler
Stainless steel band-style exhaust clamps (Lap Joint style)”
Getting Rid of the Stock Muffler
The Jeep Wrangler has a large muffler running across the rear end of the vehicle. It doesn’t look great and it doesn’t create much engine sound, so in making your own custom exhaust system, the first step is to get the ugly stock muffler out of the way. The stock muffler is just bolted up to the exhaust pipe, so you simply loosen the clamp, loosen the hangers and the whole assembly drops out of the vehicle.
Some Wrangler owners will want to run a simple tailpipe out of the back of vehicle from where the muffler was attached, but this DIY does not have the extra piping out back.
Once the factory muffler is out of the way, the OP figured out where he wanted the Summit glasspack muffler to sit by measuring and marking the long exhaust pipe that runs under the cab of the Jeep. Using the Sawzall, he made two cuts, removing a section of the stock pipe and making room for the new muffler to bolt into place.
With the lap-joint style clamps, the muffler was secured in place and the project was complete.
Finished Project
In the end, this DIY cleans up the underside of the Wrangler’s rear end while adding a touch of grumble from the exhaust muffler. The OP also states that Summit claims a 21-horsepower gain and while that seems a bit extreme, it seems reasonable that the added exhaust flow improves engine performance by at least a few horsepower.
“I did enlist my wife to approve of the sound test and I am proud to say my JK passed. It has a deep throaty sound without the ‘too fast too furious’ rice burner tone. It has improved felt horsepower along with my CAI. Summit Racing estimates at least 21 horse power increase with their products.”
More importantly, the system looks and sounds better than stock, all for well under $100. Click here to check out the original custom exhaust DIY post with the step-by-step explanation of how to make your own custom cat-back exhaust for your Wrangler.
