Mopar Showcases New JPP Ultimate Dana 44 AdvanTEK Axles at SEMA
New performance axles for all-new Jeep Wrangler are set to hit the market next month.
Mopar has teamed up with Dana to introduce new Jeep Performance Parts (JPP) axles for the all-new Jeep Wrangler. JPP Ultimate Dana 44 AdvanTEK axles are on display in Mopar’s exhibit at the 2018 Specialty Equipment Market Association (SEMA) show in Las Vegas.
The JPP Ultimate Dana 44 AdvanTEK axles have also been installed in the Nacho Jeep Wrangler concept, which is also on display in the Mopar exhibit. The collaboration between Mopar and Dana, a continuation of a 70-year-plus relationship, delivers OEM quality to current-generation Jeep Wrangler owners.
“Performance axles for the all-new Jeep Wrangler are the latest additions to our extensive line of parts and accessories for hardcore off-roaders,” said Steve Beahm, Mopar’s Head of Parts. “From lift kits to beadlock wheels to LED lights and now performance axles, the Mopar brand has trail enthusiasts covered with more than 200 Jeep Performance Parts.”
Made in the USA, JPP Ultimate Dana 44 AdvanTEK axles are built strong so hardcore Jeep Wrangler off-roaders can go where others fear to tread. High-strength features include AdvanTEK gear technology that reduces gear set packaging with more strength and durability, allowing for a condensed carrier and improving ground clearance.
Chromoly 4340 axle shafts, thicker quarter-inch steel bracket mounts, thicker 9.5 mm tubes and upgraded 1410 U-Joints also increase trail durability. A nodular iron differential cover adds to the rugged appearance while providing extra ribbing for strength and increasing overall rigidity.
The high-clearance carrier design adds an additional half-inch of ground clearance, and an expanded range of gear ratios (4.56, 4.88, 5.13 and 5.38) helps accommodate for a variety of tire sizes. The direct bolt-in axle assembly allows use of OEM components and provides virtual “plug and play.” The axle assembly includes electronic differential lockers already installed.
JPP Ultimate Dana 44 AdvanTEK axles will be available to the public in November.
You must be logged in to post a comment.
