Jeep Wrangler JK Wheel Spacers: How-To Spotlight
Some aftermarket adjustments can be challenging and time-consuming. Others are a process of routine adjustments. Wheel spacers fall into the second category.
Depending on the rim and wheel combination and the look you are going for, wheel spacers can be a quick and easy way to give your Jeep JK a modified look without a ton of additional effort. To some, the change in the before and after look of wheel spacers is simply subtle. In some cases, that subtlety can be just enough to give the look that you are wanting to see. Even if some people may not even notice that you made the modification.
For those of you who are not familiar with the product, it really is a basic modification where you’re a pro after the first try. There are certainly steps that need to be watched, because if you miss a step you can damage quite a bit of your ride, fairly fast. So what does it take to install wheel spacers? Today’s How-To Spotlight article walks you through the process from start to finish.
CHECK OUT: The Entire JK Forum How-To Article
The wheel spacer is not limited to the Jeep JK; there are many other vehicles that benefit, and the steps are nearly identical in most instances.
Is this a modification that you have made to your JK? What was the result or look that you were shooting for? Did you run into any unexpected problems? Anything that you would change or do differently? We would love to see your before and after photos, so make sure to attach them!
