Jeep Trackhawk Sets New Quarter-mile World Record in Texas
Hennessey’s 1200-horsepower monster Jeep ran a 9.66 at 145 miles per hour, the quickest anyone has ever gone in an SUV.
Since the Jeep Grand Cherokee Trackhawk hit the streets, owners have been adding power to the supercharged SUV. While 707 horsepower and 645 lb-ft of torque coupled with a stock quarter-mile time in the mid-11-second range is plenty for the average buyer, those owners who frequent the drag strip want more power and quicker times. One such owner turned to Hennessey Performance in the above video from their official YouTube page for that extra power and the results are record-setting.
The Hennessey-built Jeep Grand Cherokee Trackhawk in the video above packs more than a thousand horsepower at the rear wheels, allowing it to cover the quarter mile in just 9.66 seconds. No Trackhawk has run that far into the 9s, making this Jeep the quickest and fastest of its kind in the world.
HPE1200
The Jeep in the video above is equipped with Hennessey’s HPE1200 package. It is named that because the package is designed to deliver 1,200 horsepower at the crankshaft, which translates to 1,003 horsepower and 892 lb-ft of torque at the rear wheels. It should be noted that this Grand Cherokee is all-wheel-drive, but when tested on a rear-wheel dynamometer, it made over a thousand at the rear wheels. On an all-wheel-drive dyno, those numbers would be a bit lower, but for this story, all that really matters is the track times.
To make this 5,500-pound SUV so quick, Hennessey started by installing ported cylinder heads, a new camshaft and a new bottom end with a balanced rotating assembly, forged connecting rods and forged pistons. Next, a 4.5-liter Whipple supercharger, a cold air intake, stainless steel headers and high-flow catalytic convertors help the engine breathe better on both ends while larger fuel injectors and a Kenne Bell Boost-A-Pump helps to provide the fuel needed to feed the monstrous Hemi.
Finally, once everything is installed, Hennessey tuned this Jeep to run on 109-octane racing fuel, leading to the lofty power numbers mentioned above.
Record Run
In the video above, the Hennessey-tuned Jeep Trackhawk is working out on the quarter mile track at Lonestar Motorsports Park in Texas. With some interior removed for weight reduction, the Grand Cherokee pulls into the burnout box, smoking the rear tires only before easing to the starting line, at which point all-wheel-drive was engaged.
When the green lights dropped, the Trackhawk ripped away from the line at just over idle. Even with a rough 1-2 shift, the Jeep roars down the track, stopping the timers on the top end with a 9.66 at 145.49 miles per hour. On that run, this Grand Cherokee got the 60-foot mark in just 1.5433 seconds and it got to the eighth-mile marker in just 6.27 seconds at 115 miles per hour.
While the cool temperatures are likely to bring about more Trackhawks in the mid-9s and quicker, right now, this Hennessey HPE1200-equipped Jeep is the quickest of its kind in the world.
Crank up your speakers and enjoy.
